I’ve update Seafile Pro from 11.0.7 to 11.0.8 today using the .tar.gz archive for Ubuntu.
When Seadrive client on Windows is running (version 3.0.9 and 3.0.10) it returns a Internal server error and the sync doesn’t work.
The server keeps spitting out errors in fileserver-error.log:
2024/06/21 17:31:18 http: panic serving 172.16.255.4:46858: runtime error: invalid memory address or nil pointer dereference
goroutine 1006 [running]:
net/http.(*conn).serve.func1()
/usr/lib/go-1.21/src/net/http/server.go:1868 +0xb9
panic({0x8dc2c0?, 0xf1f640?})
/usr/lib/go-1.21/src/runtime/panic.go:920 +0x270
io.copyBuffer({0xa53900, 0xc0039c04d0}, {0x0, 0x0}, {0x0, 0x0, 0x0})
/usr/lib/go-1.21/src/io/io.go:430 +0x18b
io.Copy(...)
/usr/lib/go-1.21/src/io/io.go:389
os.genericReadFrom(0xc0039c04d0?, {0x0?, 0x0?})
/usr/lib/go-1.21/src/os/file.go:161 +0x35
os.(*File).ReadFrom(0xc0039c04d0, {0x0, 0x0})
/usr/lib/go-1.21/src/os/file.go:155 +0x9c
io.copyBuffer({0xa52920, 0xc0039c04d0}, {0x0, 0x0}, {0x0, 0x0, 0x0})
/usr/lib/go-1.21/src/io/io.go:416 +0x147
io.Copy(...)
github.com/seafileltd/seafile-pro-server/fileserver/objstore.(*fsBackend).write(0xc00017eba0, {0xc003423a9b?, 0xc000014650?}, {0xc00006eb25, 0x28}, {0x0, 0x0}, 0x98?)
/seafile-code/seafile-pro-server/fileserver/objstore/backend_fs.go:68 +0x269
github.com/seafileltd/seafile-pro-server/fileserver/objstore.writeBlock(0xc00007c140, {0xc003423a9b, 0x24}, {0xc00006eb25, 0x28}, {0x0, 0x0}, 0x0?)
/seafile-code/seafile-pro-server/fileserver/objstore/objstore.go:344 +0xa4
github.com/seafileltd/seafile-pro-server/fileserver/objstore.(*ObjectStore).Write(0xc00007c140?, {0xc003423a9b?, 0x24?}, {0xc00006eb25?, 0x28?}, {0x0?, 0x0?}, 0x0?)
/seafile-code/seafile-pro-server/fileserver/objstore/objstore.go:224 +0x1c7
github.com/seafileltd/seafile-pro-server/fileserver/blockmgr.Write(...)
/seafile-code/seafile-pro-server/fileserver/blockmgr/blockmgr.go:177
main.putSendBlockCB({0xc003555900?, 0x100?}, 0xc003555900)
/seafile-code/seafile-pro-server/fileserver/sync_api.go:2005 +0x59f
main.blockOperCB({0xa56e48?, 0xc000162ee0?}, 0x100?)
/seafile-code/seafile-pro-server/fileserver/sync_api.go:1954 +0x65
main.appHandler.ServeHTTP(0xc003555800?, {0xa56e48, 0xc000162ee0}, 0xc003555900)
/seafile-code/seafile-pro-server/fileserver/fileserver.go:739 +0x122
github.com/gorilla/mux.(*Router).ServeHTTP(0xc00011a000, {0xa56e48, 0xc000162ee0}, 0xc003555700)
/root/go/pkg/mod/github.com/gorilla/mux@v1.7.4/mux.go:210 +0x1c5
net/http.serverHandler.ServeHTTP({0xa54f60?}, {0xa56e48?, 0xc000162ee0?}, 0x6?)
/usr/lib/go-1.21/src/net/http/server.go:2938 +0x8e
net/http.(*conn).serve(0xc0000f4000, {0xa57760, 0xc003231a70})
/usr/lib/go-1.21/src/net/http/server.go:2009 +0x5f4
created by net/http.(*Server).Serve in goroutine 1
/usr/lib/go-1.21/src/net/http/server.go:3086 +0x5cb
