Hi guys! I’m trying to set my seaf-cli to sync also locally one of the libraries within my headless server. If I start it manually from the normal ubuntu user (seaf-cli start), then it works as expected, but I don’t seem to be able to configure it as a service. Whenever I try to run it, I get:
$ sudo service seafile-client start Warning: seafile-client.service changed on disk. Run 'systemctl daemon-reload' to reload units. Job for seafile-client.service failed because the control process exited with error code. See "systemctl status seafile-client.service" and "journalctl -xe" for details.
$ systemctl status seafile-client.service
Warning: seafile-client.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
● seafile-client.service - Seafile client
Loaded: loaded (/etc/systemd/system/seafile-client.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2018-06-13 10:14:32 HKT; 30s ago
Process: 25903 ExecStart=/usr/bin/seaf-cli start (code=exited, status=217/USER)
Main PID: 25903 (code=exited, status=217/USER)
CPU: 0Jun 13 10:14:32 SeafileServer systemd[1]: Starting Seafile client…
Jun 13 10:14:32 SeafileServer systemd[1]: seafile-client.service: Main process exited, code=exited, status=217/USER
Jun 13 10:14:32 SeafileServer systemd[1]: Failed to start Seafile client.
Jun 13 10:14:32 SeafileServer systemd[1]: seafile-client.service: Unit entered failed state.
Jun 13 10:14:32 SeafileServer systemd[1]: seafile-client.service: Failed with result ‘exit-code’.
