I’m having problems accessing the seafile via webdav.
“Sorry, but the requested page could not be found.”
It was working and for some reason it isn’t working anymore and I can’t figure out why.
I’m in Arch Linux with seafile-pro-server_6.2.9_x86-64.tar.gz installed mannually as in the manual.
I use mysql and Apache with SSL.
Here’s my logs and configuration files.
$ tail -f ccnet.log
[03/20/18 21:28:07] ../common/session.c(409): Accepted a local client
$ tail -f controller.log
[03/20/18 21:28:44] seafile-controller.c(575): pid file /srv/seafile/cal/pids/seafdav.pid does not exist
[03/20/18 21:28:44] seafile-controller.c(606): seafdav need restart...
[03/20/18 21:28:44] seafile-controller.c(87): spawn_process: /usr/bin/python2.7 -m wsgidav.server.run_server --log-file /srv/seafile/cal/logs/seafdav.log --pid /srv/seafile/cal/pids/seafdav.pid --port 8080 --host localhost
[03/20/18 21:28:44] seafile-controller.c(102): spawned /usr/bin/python2.7, pid 24101
$ vi ccnet.conf
[General]
USER_NAME = xxxxx
ID = XXXXXXXXXXXXXXXXXXXXXXXXXXX
NAME = xxxxx
SERVICE_URL = https://xxxxx.xxxx.xxx
[Client]
PORT = 13419
[Database]
ENGINE = mysql
HOST = 127.0.0.1
PORT = 3306
USER = seafile
PASSWD = xxxxxxxxxx
DB = ccnet-db
CONNECTION_CHARSET = utf8
$ vi seahub_settings.py
# -*- coding: utf-8 -*-
SECRET_KEY = "XXXXXXXXXXXXXXXXXXXXXXXXXX"
DATABASES = {
'default': {
'NAME': 'seahub-db',
'USER': 'seafile',
'PASSWORD': 'XXXXXXXXXX',
'HOST': '127.0.0.1',
'PORT': '3306'
FILE_SERVER_ROOT = 'https://xxxxx.xxxx.xxx/seafhttp'
EMAIL_USE_TLS = True
EMAIL_HOST = 'xxxx.xxxx.xxx'
EMAIL_HOST_USER = 'xxx@xxxx.xxx'
EMAIL_HOST_PASSWORD = 'xxxxxxxxxxx'
EMAIL_PORT = 587
DEFAULT_FROM_EMAIL = "xxxx@xxxxx.xxx"
SERVER_EMAIL = "xxxx@xxxxx.xxx"
ENABLE_RESUMABLE_FILEUPLOAD = True
$ vi seafdav.conf
[WEBDAV]
host = localhost
enabled = true
port = 8080
fastcgi = false
share_name = /seafdav
$ vi /etc/httpd/conf/extra/httpd-vhosts.conf
<VirtualHost *:443>
ServerName xxxx.xxxx.xxx
DocumentRoot /etc/httpd
SSLEngine On
SSLCertificateFile /etc/httpd/conf/cacert_seafile.pem
SSLCertificateKeyFile /etc/httpd/conf/privkey_seafile.pem
Alias /media /srv/seafile/cal/seafile-server-latest/seahub/media
<Location /media>
Require all granted
</Location>
RewriteEngine On
# seafile fileserver
# WebDAV
# We use http proxy, since SeafDAV is incompatible with FCGI proxy in Apache 2.4.
ProxyPass /seafdav http://127.0.0.1:8080/seafdav
ProxyPassReverse /seafdav http://127.0.0.1:8080/seafdav
# seahub
SetEnvIf Request_URI . proxy-fcgi-pathinfo=unescape
ProxyPass / fcgi://127.0.0.1:8000/
</VirtualHost>
Don’t know if this helps:
/usr/bin/python2.7: No module named wsgidav.server
