Seafile 12 LDAP can't connect
Hi, I’m still working on seafile, I installed version 12 in docker. But I also have an LDAP error. The configuration is the same (I tried changing different values)
Summary
ENABLE_LDAP = True
LDAP_SERVER_URL = ‘ldap://192.168.4.3’
LDAP_BASE_DN = ‘ou=Users,dc=domain,dc=lcl’
LDAP_ADMIN_DN = ‘admin@domain.lcl’
LDAP_ADMIN_PASSWORD = ‘pass’
LDAP_PROVIDER = ‘ldap’
LDAP_LOGIN_ATTR = ‘mail’
LDAP_LOGIN_ATTR = ‘userPrincipalName’
#LDAP_CONTACT_EMAIL_ATTR = ‘’
LDAP_CONTACT_EMAIL_ATTR = ‘mail’
LDAP_USER_ROLE_ATTR = ‘’
LDAP_USER_FIRST_NAME_ATTR = ‘givenName’
LDAP_USER_LAST_NAME_ATTR = ‘sn’
LDAP_USER_NAME_REVERSE = False
LDAP_FILTER = 'memberOf=cn=Seafile,ou=Users,dc=domain,dc=lcl’
[2025-10-29 16:55:38] [ERROR] django.request:241 log_response Internal Server Error: /api/v2.1/admin/ldap-users/ [2025-10-29 16:55:39] [ERROR] seahub.api2.endpoints.admin.users:946 get (11, ‘Resource temporarily unavailable’)
[2025-10-29 16:51:35] [ERROR] django.request:241 log_response Internal Server Error: /api/v2.1/admin/ldap-users/ [2025-10-29 16:51:36] [ERROR] seahub.api2.endpoints.admin.users:946 get Failed to get users from ldap server: {‘result’: -7, ‘desc’: ‘Bad search filter’, ‘ctrls’: }.
these are different configuration options. Can you tell me where the error is?
You have LDAP_LOGIN_ATTR defined twice.
You can also try to log in to the Seafile Docker container and use the ldapsearch command to verify if you can connect to LDAP manually. The command is like follows:
#-H LDAP_SERVER_URL#-b LDAP_BASE_DN
#-D LDAP_ADMIN_DN
#'(objectClass=person)'   LDAP Filter
#-W After executing this command, enter the password manually.
ldapsearch -x -H ldap://192.168.4.3/ -b 'cn=users,dc=hacn,dc=local' '(objectClass=person)' -D 'administrator@hacn.local' -W -LLL
Hi, I spent a lot of time solving this problem. I tested the script and it works. I compared the entries and saw differences only in the “/” at the end of the line, with the value
LDAP_SERVER_URL = ‘ldap://192.168.4.3/’.
Thank you very much, I’ll keep working on it.
Thank you for your feedback! After analyzing your logs, we’ve identified two types of errors you’re encountering:
  1. “Resource temporarily unavailable” – this occurs when connecting to the LDAP server.
  2. “Bad search filter” – this is caused by an invalid LDAP filter (LDAP_FILTER).
You suspect the issue might be related to whether the LDAP_SERVER_URL ends with a trailing slash “/”. However, we haven’t been able to reproduce this problem in our internal tests. We recommend testing with the following steps:
First, omit the LDAP_FILTER configuration. This will default to searching all AD users. With LDAP_FILTER unset, test by adding or removing the trailing “/” in the SERVER_URL to see if the LDAP connection works properly.
Seafile’s LDAP user access relies on the python-ldap package. According to the documentation, the LDAP URI does not require a trailing “/” at the end.
On the other hand, you also can test it by a python scripts to see which one will raise an error:
import ldap
server_url = “ldap://192.xx.xxx.“
server_url_slash = “ldap://192.xxx.xxx/“
conn1 = ldap.initialize(server_url)
conn2 = ldap.initialize(server_url_slash)
Hi, I must have made a mistake. I rechecked the configuration and removed the / at the end of the line. And it works.
But now I can’t solve the problem with the access group - Seafile.
I added the line:
LDAP_FILTER = ‘memberOf=CN=Seafile,OU=TSK,DC=domain,DC=lcl’
dsquery group -name seafile
“CN=Seafile,OU=TSK,DC=domain,DC=lcl”
And the LDAP button is no longer available.
11-11-2025 133509
Are there any errors in seahub.log?
Docker compose 12 version startup error when restarting.
Error:Seahub failed to start.
  File "/scripts/start.py", line 94, in <module>
    main()
  File "/scripts/start.py", line 80, in main
    call('{} start'.format(get_script('seahub.sh')))
  File "/scripts/utils.py", line 70, in call
  File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
subprocess.CalledProcessError: Command '/opt/seafile/seafile-server-12.0.14/seahub.sh start' returned non-zero exit status 1.
If I disable
#LDAP_FILTER = ‘memberOf=CN=Seafile,OU=domail,dc=tsgk,dc=lcl’
it works, but the logs are in seahub.log:
[2025-11-12 16:22:16] [ERROR] seahub.utils.timeutils:65 timestamp_to_isoformat_timestr ‘<=’ not supported between instances of ‘int’ and ‘NoneType’
  • In version 13, the logs show this error:
[2025-11-12 16:44:56] [ERROR] seahub_settings.py load: SyntaxError: unterminated string literal (detected at line 32) (seahub_settings.py, line 32)
  File "/opt/seafile/seafile-server-13.0.12/seahub/seahub/settings.py", line 1167, in <module>
    import seahub_settings
  File "/opt/seafile/conf/seahub_settings.py", line 32
    LDAP_FILTER = 'memberOf=CN=Seafile,OU=TSK,DC=dimain,DC=lcl’
[2025-11-12 11:45:04] [WARNING] django.security.SuspiciousSession:138 decode Session data corrupted
The service starts, but there’s no LDAP button.
As the error indicated, you should make sure the quote character (’) at the end of the line is a correct English quote character (').
I feel uneasy, that’s true. Thank you very much for your quick reply. My inattention has let me down again.
I got the same probleme here.
I started testing SeaFile with version 12 a few weeks ago.
In version 12, it used to work with outer parenthesis in the LDAP filter
After migrating to version 13, outer parenthesis must be removed
This may be caused by the included python LDAP library has been upgraded.
