just installed a fresh docker deployed instance of seafile CE 12 following this documentation: https :// manual . seafile . com / 12.0/setup/setup_ce_by_docker/
Apologies in advance, when I tried to save this post, it said “you cannot add links”, which is why I reformated URLs.
Brief problem description
Seafile itself works quite nice and I can upload files successfully.
However, the wiki isn’t working. The ui simply shows a popup saying “error” at the top and in the JS console, I can see
Failed to load resource: the server responded with a status of 404 (Not Found)
while trying to access
https :// foo.bar.com / sdoc-server / api/v1/docs/<HASH>/
Detailed Description
I already have a reverse proxy running on my server and initially I tried to compose seafile with its own reverse proxy cady. So: web -> nginx -> caddy -> seafile.
Then I found this article https :// forum. seafile. com /t/err-too-many-redirects-with-nginx-and-custom-seafile-ports/23362 which suggests to get rid of caddy entirely, which I did and it works.
Here are the changes I’ve made
Disable Caddy
I removed caddy.yml from the COMPOSE_FILE variable in the .env file in order to disable the caddy service.
Dot env file
COMPOSE_FILE='seafile-server.yml,seadoc.yml'
COMPOSE_PATH_SEPARATOR=','
SEAFILE_SERVER_HOSTNAME=foo.bar.com
SEAFILE_SERVER_PROTOCOL=https
ENABLE_SEADOC=true
seahub settings
CSRF_TRUSTED_ORIGINS = ['https://foo.bar.com']
Port 80 for seafile service
I modified seafile-server.yml to map port 80
seafile:
image: ${SEAFILE_IMAGE:-seafileltd/seafile-mc:12.0-latest}
container_name: seafile
- "172.17.0.1:8877:80"
Port 80 for seadoc service
seadoc:
image: ${SEADOC_IMAGE:-seafileltd/sdoc-server:1.0-latest}
container_name: seadoc
- ${SEADOC_VOLUME:-/opt/seadoc-data/}:/shared
- "172.17.0.1:8866:80"
Nginx
Here are the modifications that I made to my “old” reverse proxy:
listen 443 ssl;
server_name foo.bar.com;
ssl_certificate SNIP;
ssl_certificate_key SNIP;
proxy_read_timeout 310s;
proxy_set_header Host $host;
proxy_pass http://172.17.0.1:8877/;
proxy_http_version 1.1;
location /sdoc-server {
proxy_pass http://172.17.0.1:8866/;
location /socket.io {
So in essence everything / routed to the seafile service (port 8877) and everything /sdoc-server and /socket.io to the seadoc service.
If I click on the wiki, a new tab opens and the small popup opens at the top saying “error”. The Console says Failed to load resource: the server responded with a status of 404 (Not Found). If I manually click on the URL shown next to it (https://foo.bar.com/sdoc-server/api/v1/docs/<HASH>/) I get this error message: {"error_msg":"You don't have permission to access."}
Update*:
Seadoc doesn’t work either - I just learned what seadoc actually is, didn’t know about that specific *.sdoc format and associated editor.
When I create an *.sdoc inside a library and try to open it, I get this body:
Load doc content error
Console:
code ERR_BAD_REQUEST
message Request failed with status code 404
url "https://foo.bar.com/sdoc-server/api/v1/docs/54c5b33e-b6a1-4a2a-bbd3-a89e763d8aee/"
data Cannot GET //api/v1/docs/54c5b33e-b6a1-4a2a-bbd3-a89e763d8aee
