We are excited to announce that Seafile 13.0 is now available for testing! This new version brings a host of powerful features designed to enhance your file management and collaboration experience.
The final production ready version will be available in the end of this year.
Key updates:
Extended file properties with a new metadata-server component
Multiple view types for file display
Hierarchical tag management
Realtime UI updates via notification-server
Thumbnail server: A new thumbnail server component is added to improve performance for thumbnail generating and support thumbnail for videos
Seafile AI
SeaDoc is now version 2.0 and includes AI integrations
Seafile 13.0 beta version is safe to use in production in general if you don’t use the new metadata feature. Other features are small changes from version 12.0.
What I mean is that the 13.0 docs linked in the post say to use this https://manual.seafile.com/13.0/repo/docker/ce/seafile-server.yml for the main Seafile Server which has;
The inline deafult value uses a tag that does not exist on Docker Hub and will show a manifest not found error if ${SEAFILE_IMAGE} is not explicitly set.
All the other images in the 13.0 docs use inline default values that correctly exist on Docker Hub. E.g.;
The thumbnail sever is giving me some issues (as in not working at all).
The thumbnail.log complains about missing directory:
[2025-07-14 16:38:18] [ERROR] app:44 Failed to init thumbnail information: [Errno 2] No such file or directory
but which one is this? In seahub-data “thumbnail” folder was correctly created, but is empty. All my seafile-data is on another volume and configured with a symlink and Ive made sure that the thumbnail-server dock has access to this (confirmed via bash inside the container itself).
I am also using nginx where I have made this location block:
The 8883 port is forwarding to 80 inside the thumbnail server. It just gives a {"error": "Internal Server Error"} Ive tried without SSL and with, also without and with trailing /
Cool. What’s the ETA on the release? My thumbnails are currently broken. Could possibly just revert to the old method, I guess, but why bother if there’s a fix coming up.
