Seafile 13.0 is ready!
We’re thrilled to announce the official release of Seafile 13.0 — a milestone update that transforms Seafile from a simple sync-and-share tool into a smarter, more collaborative, and AI-augmented file platform. With richer metadata, flexible views, integrated AI, and powerful in-browser document editing, this release unlocks entirely new ways to organize, discover, and work with your files.
Here’s a quick overview of the major new features in Seafile 13.0:
  • Extended file properties with a new metadata server
  • Multiple view types: Table, Kanban, Gallery, Map, Card, and Statistics
  • Hierarchical tag management
  • Real-time UI updates via notification server
  • Dedicated thumbnail server (videos, images, PDFs)
  • Seafile AI: extract file details and text, generate descriptions and tags, detect faces
  • SeaSearch production-grade full-text search
  • SeaDoc 2.0: block-based editor, AI assistance, whiteboards (Excalidraw)
  • Wikis: block-based editing, comments, Ask AI, sdoc / Markdown import & export
To learn more, please visit:
Blog: Seafile 13.0 is ready!
Video overview: Seafile 13: A new way to organize your files
Is there documentation, instructions or a manual available, how to move from 12 binary to 13 docker? I am running Ubuntu 24 LTS and would like to move to 13 but it is only unfortunately only available via docker …
You can first change to docker based deployment in version 12.0, then upgrade to version 13.0.
So no standalone release anymore?
Only docker?
Onle for pro version all is here : Outline - Seafile Admin Manual
i have the community version -12.0.14 Are there instructions on how to upgrade to 13 and how to revert back in case it doesn’t start
You probably want to look at the upgrade notes here: Outline - Seafile Admin Manual
There isn’t exactly a downgrade option. There might be changes made that aren’t compatible with the older version, especially in the database. You should have backups before trying the upgrade, and it would be a good idea to snapshot your VM (if your server is a VM) before you begin.
No VM and I know nothing about Docker Guess I;ll image the drive
how do i know which I have
Deployment with Seafile
or
Standalone deployment
That appears to be 2 different versions of the notification-server.yml, one with the caddy stuff, and one one without. So I think it’s a little mislabeled. Instead of being “with seafile” and “standalone”, it looks like it should be labeled “with caddy” and “without caddy”.
We upgraded to this v13 release, and …
Congrats guys ! it a really good and appreciated release :+1:
Good job, thanks :slight_smile:
