Seafile 14.0 Is Ready for Testing
Seafile 14.0 is now ready for testing. This release introduces AI Chat for finding and understanding content in your libraries, and it brings a wide range of improvements across the interface, search, file properties, Wiki, SeaDoc, and more. Here are the highlights:
  • AI Chat for exploring your libraries
  • An updated search experience with SeaSearch and AI Chat
  • A more refined interface, with improved navigation and file browsing
  • More flexible file properties and a new data table view
  • New Wiki and SeaDoc capabilities and interaction improvements
  • Improvements to configuration, sharing links, Webhooks, file previews, and more
1. AI Chat for Your Libraries
Seafile 14.0 introduces AI Chat, which lets you ask questions about a library’s contents and explore its structure through conversation. Instead of browsing folder by folder, you can ask AI Chat to help you find relevant files, understand what a folder contains, analyze how files are distributed, or identify ways to organize the library. For example, you can ask:
  • β€œFind the files related to this project.”
  • β€œWhat files are under this folder?”
  • β€œAnalyze the file distribution in this library.”
  • β€œHow could I improve the organization of this library?”
AI Chat works with library metadata, including file names, paths, sizes, AI-generated summaries, and other file properties. It can also help identify potentially similar or duplicate files and summarize the information available for the files in a folder. This gives you a broader view of your library without opening and inspecting files one by one.
Analyze your library with AI Chat
2. An Updated Search Experience
Seafile 14.0 brings an updated search experience with SeaSearch and AI Chat. SeaSearch provides full-text and vector search, while AI Chat adds a conversational way to find relevant documents.
  • Regular search lets you choose the scope: the current library, the current folder, or all libraries.
  • AI Chat works at the library level. Within a library, ask any question, and AI Chat finds relevant files based on the library’s metadata. For example, ask it to find the documents related to a project or to locate the files under a particular folder.
Ask AI Chat to find relevant documents
3. A More Refined User Interface
Seafile 14.0 continues to improve the user interface, with updates to icons, UI components, navigation, layout, and file browsing.
3.1 Redesigned Icons and UI Components
All Seafile icons have been redrawn in a more consistent visual style. Buttons, dropdowns, menus, dialogs, and other UI components have also been refined to match.
Updated Seafile interface
3.2 Improved Navigation and Layout
Navigation, page layout, colors, and other visual details have been refined throughout the interface. Inside libraries, a New button now makes creating and uploading files easier to find.
New button for creating, uploading, or importing files.
3.3 New Image Viewer
The image viewer has been upgraded with a new interface.
Updated image viewer with thumbnails, zoom, rotation, and original image access.
3.4 Video Preview in Grid View
In Grid View, you can now preview a video by moving the mouse over it.
3.5 Improved Trash and History Pages
The Trash and History pages now use a table layout, so you can search and filter records right on the page.
Search and filter records in History
4. More Flexible File Properties and Views
Seafile 14.0 gives you more flexibility in how you view and work with file properties.
4.1 Customizable File Properties in the File List
You can now customize the file list to show the properties that matter to your workflow, such as AI summaries and tags.
AI summary and Tags in List View
4.2 New Data Table View
The new data table view shows the files in a folder as a table, making it easier to review and edit properties such as status, tags, and collaborators.
New data table view with file status, tags, AI summaries, and an open tag picker.
4.3 Metadata Backup and Restore
Backing up and restoring metadata is now more convenient. You can export metadata to an Excel backup file, or restore it from a backup file previously exported by Seafile.
5. Wiki and SeaDoc Improvements
Seafile 14.0 adds new capabilities to both Wiki and SeaDoc, along with a range of interaction improvements.
5.1 New Editing Capabilities
Both Wiki and SeaDoc now support:
  • LaTeX math formulas
  • Multi-column layouts, created by dragging blocks
  • Dragging code blocks into lists
  • Divider elements
  • Collapsible headings and long code blocks
  • Foldable lists and annotation lines
  • Images that link to URLs (in Wiki, images can also link to another Wiki page)
  • Image uploads on mobile devices
  • Improved PDF printing
Folding lists and adding annotation lines
5.2 Wiki Improvements
Wiki gets improvements to search, publishing, customization, and video support.
  • Search: Global search now works across multiple Wikis.
  • Publishing: Published Wikis can use server-side rendering for a more SEO-friendly experience.
  • Customization: Wiki pages support custom cover images. Wiki icons and theme colors can be customized: when creating a Wiki, choose from 300+ icons, search or browse the available icons, or use Auto match to let AI suggest an icon based on the Wiki name. You can refresh the suggestions for more options and choose an icon color.
  • Video: You can insert video links, insert videos below block elements, and adjust the displayed video size.
Choose Wiki icons or use AI Auto match
6. Configuration and Architecture Improvements
Seafile 14.0 includes configuration and architecture improvements that make installation and maintenance more straightforward. These include:
  • Environment-variable configuration for Seafile WebDAV ( seafdav ) and metadata-related functionality
  • SeaSearch as the default search engine, configured through environment variables
  • Removal of the dependency of md-server on seafile.conf
  • Improved Thumbnail Server configuration
7. Other Improvements
Seafile 14.0 also includes improvements to sharing, administration, integrations, and file format support.
  • Share and Upload Links: You can now add descriptions to Share Links and Upload Links.
  • Webhooks: You can configure a Webhook to receive reports when a library is modified.
  • Dark mode for admin pages: The System Admin and Team Admin pages now support dark mode.
  • More file format support: Seafile can now:
    open .csv files with OnlyOffice.
    preview TIFF images.
    play .mkv and .m4v videos in web browsers.
    generate thumbnails for EPUB files.
Start Testing Seafile 14.0
Try AI Chat, explore the refined interface, and check out the improvements to Wiki, SeaDoc, file properties, and search. We welcome your feedback as we continue preparing Seafile 14.0 for release.
Nice new features, I like :grin:
Couple of questions though:
  • Are all of these features present in CE or are some reserved for Professional edition?
  • How does that work with the AI chat? Where is the LLM running, which LLM is used in the background? What kind of data is sent to the (external?) LLM?
Thank you!
Regarding your questions on Seafile 14.0 and AI Chat:
1. Feature availability between CE and Pro
  • SeaSearch (the full-text and vector search engine) is exclusive to the Professional Edition (Pro).
  • The user interface improvements, navigation and layout updates, data table views, file properties/metadata improvements, and the Seafile AI extension can be used in Community deployments (CE requires deploying the metadata server component and Redis cache).
2. How AI Chat works (LLM deployment, models, and transmitted data)
  • Where the LLM runs and which model is used: Seafile does not bundle a fixed proprietary cloud model. Instead, Seafile AI utilizes LiteLLM and OpenAI-compatible endpoints configured by the server administrator in the environment settings (.env). Administrators can configure external cloud LLM providers (such as OpenAI, Gemini, DeepSeek, or Azure) or connect to self-hosted/local models running on-premises (such as via Ollama or LM Studio).
  • What data is sent: AI Chat operates at the library level using metadata. When querying, it sends relevant metadataβ€”such as file names, paths, file sizes, properties, and summariesβ€”along with the user’s prompt to the configured LLM endpoint, rather than streaming entire document file bodies.
For more details on configuring LLM providers, you can refer to the Seafile AI documentation: Seafile AI extension - Seafile Admin Manual
I got time to do a test deployment with version 14 today. This was a new install (not an upgrade from a previous version) to test my configuration. All of the config files were based on the configuration of my β€œproduction” version 13, with changes made according to the upgrade instructions, with a few other changes to make it work from the test url.
It mostly works so far, except for the thumbnail server. The container starts, but the thumbnail server doesn’t actually work. The log shows this:
Oct 27 20:24:01 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:01,905 Load disk config: storage_dir=/opt/seafile/seafile-data/storage/commits
Oct 27 20:24:01 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:01,905 Load disk config: storage_dir=/opt/seafile/seafile-data/storage/fs
Oct 27 20:24:01 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:01,905 Load disk config: storage_dir=/opt/seafile/seafile-data/storage/blocks
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:02,141 Redis successfully connected: redis:6379
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:02,143 Initializing seafile thumbnail components
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:02,146 thread monitor started
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:02 This is a idle script (infinite loop) to keep container running.
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:02,629 Background thread error: BrowserType.launch: Executable doesn't exist at /home/seafile/.cache/ms-playwright/chromium_headless_shell-1208/chrome-headless-shel>
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: ╔════════════════════════════════════════════════════════════╗
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•‘ Looks like Playwright was just installed or updated.       β•‘
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•‘ Please run the following command to download new browsers: β•‘
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•‘                                                            β•‘
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•‘     playwright install                                     β•‘
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•‘ <3 Playwright Team                                         β•‘
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: Traceback (most recent call last):
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/seafile_thumbnail/screenshot.py", line 142, in _thread_main
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     self._loop.run_until_complete(self._async_main())
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     return future.result()
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:            ^^^^^^^^^^^^^^^
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/seafile_thumbnail/screenshot.py", line 152, in _async_main
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     await self._init_browser_and_pool()
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/seafile_thumbnail/screenshot.py", line 173, in _init_browser_and_pool
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     self._browser = await self._playwright.chromium.launch(**self.browser_launch_kwargs)
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:                     ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/usr/local/lib/python3.12/dist-packages/playwright/async_api/_generated.py", line 14547, in launch
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     await self._impl_obj.launch(
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/usr/local/lib/python3.12/dist-packages/playwright/_impl/_browser_type.py", line 97, in launch
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     await self._channel.send(
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/usr/local/lib/python3.12/dist-packages/playwright/_impl/_connection.py", line 69, in send
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     return await self._connection.wrap_api_call(
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:   File "/usr/local/lib/python3.12/dist-packages/playwright/_impl/_connection.py", line 559, in wrap_api_call
Oct 27 20:24:02 seafile-test thumbnail-server[76619]:     raise rewrite_error(error, f"{parsed_st['apiName']}: {error}") from None
Oct 27 20:24:02 seafile-test thumbnail-server[76619]: playwright._impl._errors.Error: BrowserType.launch: Executable doesn't exist at /home/seafile/.cache/ms-playwright/chromium_headless_shell-1208/chrome-headless-shell-linux64/chrome->
Oct 27 20:24:12 seafile-test thumbnail-server[76619]: Traceback (most recent call last):
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/main.py", line 90, in <module>
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:     run_server(args.loglevel)
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/main.py", line 82, in run_server
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:     thumbnail_server.start()
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/main.py", line 38, in start
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:     get_playwright_manager().start()
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/opt/seafile/thumbnail-server/seafile_thumbnail/screenshot.py", line 90, in start
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:     raise RuntimeError("Playwright manager init timeout")
Oct 27 20:24:12 seafile-test thumbnail-server[76619]: RuntimeError: Playwright manager init timeout
Oct 27 20:24:12 seafile-test thumbnail-server[76619]: Exception ignored in: <function BaseSubprocessTransport.__del__ at 0x7f0b56332200>
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/base_subprocess.py", line 126, in __del__
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/base_subprocess.py", line 104, in close
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/unix_events.py", line 767, in close
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/unix_events.py", line 753, in write_eof
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/base_events.py", line 795, in call_soon
Oct 27 20:24:12 seafile-test thumbnail-server[76619]:   File "/usr/lib/python3.12/asyncio/base_events.py", line 541, in _check_closed
Oct 27 20:24:12 seafile-test thumbnail-server[76619]: RuntimeError: Event loop is closed
Oct 27 20:24:12 seafile-test thumbnail-server[76619]: 2026-10-27 20:24:12,214 Task was destroyed but it is pending!
It looks to me like the β€œchromium_headless_shell” is installed in the container in /root/.cache, and not in /home/seafile/.cache, so thumbnail-server can’t be run with β€œNON_ROOT = true”.
