I installed Seafile 7.1 on a rpi3. It works but I would like to add Web analytics tools with Matomo (since Seafile Ltd Pro is not available for armv7).
I installed Matomo successfully but I have a last configuration step: I need to find the tracking code of my seafile cloud server as explained here :
https://developer.matomo.org/guides/tracking-javascript-guide
I should add the Javascript tracking code, for instance
<!-- Matomo --> <script type="text/javascript"> var _paq = window._paq = window._paq || []; /* tracker methods like "setCustomDimension" should be called before "trackPageView" */ _paq.push(['trackPageView']); _paq.push(['enableLinkTracking']); (function() { var u="//192.168.1.66:8090/matomo/"; _paq.push(['setTrackerUrl', u+'matomo.php']); _paq.push(['setSiteId', '1']); var d=document, g=d.createElement('script'), s=d.getElementsByTagName('script')[0]; g.type='text/javascript'; g.async=true; g.src=u+'matomo.js'; s.parentNode.insertBefore(g,s); })(); </script> <!-- End Matomo Code -->
to the tag which is often defined in a ‘header.php’, ‘header.tpl’ or similar template file.
So I add this code into the file
seafile-server-latest/seahub/seahub/templates/base.html
Then on the source code of seahub pages in the head section, I can see the code I just paste. But then on Matomo interface, I still get a message that the code was not included and I have no traffic data.
Any idea why ?
