Is the possibility to make anonymous editing links included? It’s an important missing feature, and it’s now in the professional edition, isn’t it?
So I tried to do the upgrade, and Seahub is bombing with:
[cloud@main seafile-server-latest]$ ./seahub.sh start-fastcgi
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
File "/home/cloud/seafile-server-7.0.0/seahub/manage.py", line 10, in <module>
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/django/core/management/__init__.py", line 364, in execute_from_command_line
utility.execute()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/django/core/management/__init__.py", line 308, in execute
settings.INSTALLED_APPS
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/django/conf/__init__.py", line 56, in __getattr__
self._setup(name)
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/django/conf/__init__.py", line 41, in _setup
self._wrapped = Settings(settings_module)
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/django/conf/__init__.py", line 110, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib64/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
File "/home/cloud/seafile-server-7.0.0/seahub/seahub/__init__.py", line 4, in <module>
from handlers import repo_created_cb, repo_deleted_cb, clean_up_repo_trash_cb, \
File "/home/cloud/seafile-server-7.0.0/seahub/seahub/handlers.py", line 25, in <module>
import seafevents
ImportError: No module named seafevents
Error:Seahub failed to start.
Here we go, I figured out how to get debug output with non-fastcgi start:
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn", line 9, in <module>
load_entry_point('gunicorn==19.8.1', 'console_scripts', 'gunicorn')()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/wsgiapp.py", line 61, in run
WSGIApplication("%(prog)s [OPTIONS] [APP_MODULE]").run()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/base.py", line 223, in run
super(Application, self).run()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/base.py", line 72, in run
Arbiter(self).run()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/arbiter.py", line 60, in __init__
self.setup(app)
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/arbiter.py", line 120, in setup
self.app.wsgi()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/base.py", line 67, in wsgi
self.callable = self.load()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/wsgiapp.py", line 52, in load
return self.load_wsgiapp()
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/app/wsgiapp.py", line 41, in load_wsgiapp
return util.import_app(self.app_uri)
File "/home/cloud/seafile-server-7.0.0/seahub/thirdpart/gunicorn-19.8.1-py2.7.egg/gunicorn/util.py", line 350, in import_app
__import__(module)
import seafevents
Great work - thank you.
Update worked like a charm.
Some small issues: In grid view the icons are scaled and look rather blurred and ugly. It would be nice to have some hd icons. Translation to german is incomplete, too.
Update: Unfortunately further testing revealed some errors wich made this version unusable for me.
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/core/handlers/exception.py", line 41, in inner
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/core/handlers/base.py", line 249, in _legacy_get_response
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/core/handlers/base.py", line 187, in _get_response
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/core/handlers/base.py", line 185, in _get_response
File "/opt/seafile/seafile-server-7.0.0/seahub/seahub/auth/decorators.py", line 27, in _wrapped_view
File "/opt/seafile/seafile-server-7.0.0/seahub/seahub/base/decorators.py", line 74, in _decorated
return func(request, *args, **kwargs)
File "/opt/seafile/seafile-server-7.0.0/seahub/seahub/views/file.py", line 677, in view_lib_file
is_draft = is_draft_file(repo.id, path)
File "/opt/seafile/seafile-server-7.0.0/seahub/seahub/drafts/utils.py", line 41, in is_draft_file
Draft.objects.get(origin_repo_id=repo_id, draft_file_path=file_path)
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/manager.py", line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/query.py", line 374, in get
num = len(clone)
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/query.py", line 232, in __len__
self._fetch_all()
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/query.py", line 1118, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/query.py", line 53, in __iter__
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch)
File "/opt/seafile/seafile-server-7.0.0/seahub/thirdpart/django/db/models/sql/compiler.py", line 899, in execute_sql
raise original_exception
ProgrammingError: (1146, "Table 'seahub-db.drafts_draft' doesn't exist")
At least the drafts_draft table is part of the SQL file which is used for database upgrading. See /seafile-server-7.0.0/upgrade/sql/7.0.0/mysql/seahub.sql for MySQL. You could try to execute the sql file directly in the database.
