Seafile-CLI: Waiting for confirmation to delete files
I am using seafile-cli 9.0.2.1 on Debian 11 to synchronize a folder from the Debian Server to Seafile.
Currently, the synchronization process is stuck with an error: Waiting for confirmation to delete files.
Is there a way to confirm the deletion? Or can seafile-cli client be configured in a way that no manual interaction is required?
Thanks,
Chris
Any information on this?
In the log file, I found:
sync-mgr.c(1035): Delete more than 500 files, add delete confirmation.
To overcome the problem:
seaf-cli config -k delete_confirm_threshold
→ no value specified (500 by default)
Set it to a larger number:
seaf-cli config -k delete_confirm_threshold -v 10000
Restart:
seaf-cli stop
seaf-cli start
and after some seconds
seaf-cli status
it says "synchronized " !
Thanks for this solution! Do you know how I can make this change permanent?
Hello Seafile Community !
I have faced a similar situation using the Seafile Client for Windows.
Do you know if there is a way to configure this threshold value on the client ?
Thanks !
On Windows you can change it in the settings dialog.
Hello @Jonathan
I’ve looked for it before and didn’t see it… but it is there, thank you !
