Hello all,
A new version of the sync client is released.
Change logs:
- Fix sync error icon in main window
- Handle filename case conflicts better when downloading (don’t download file with case conflicts)
- Improve conflict handling in cloud file browser
- Add sort library feature in main window
- Support username and password when use SOCKS5 proxy
- Requires at least version 2 encryption protocol when creating an encrypted library (Thanks to Jonas Hofmann and Kien Tuong Truong from ETH Zurich)
- Change local file permission when recieving unlock event from notification server
- [mac] Update system tray icon
- [linux] ensure only one seaf-daemon running for each account
- [linux] Support reading parameters from configuration file
If you use encrypted libraries it’s suggested you upgrade to this client version. Encrypted libraries with version 1 encryption protocol use weaker encryption technologies. If a malicious server admin deliberately set the encryption protocol version to 1 on the server side, it may harm the security of encryption. 9.0.6 client refuses to create encrypted libraries with encryption protocol version 1.
