Running Windows 11:
seafile.log show:
[12/24/23 19:05:59] starting seafile client 9.0.4
[12/24/23 19:05:59] client id = 1a42fbc3291c8a204ff2301ce2489eae90123c17, client_name = Pappa
[12/24/23 19:05:59] rpc server started.
[12/24/23 19:06:00] start to serve on pipe client
[12/24/23 19:06:01] start to serve on pipe client
[12/24/23 19:06:09] File syncing protocol version on server https://files.xxx is 2. Client file syncing protocol version is 2. Use version 2.
[12/24/23 19:06:10] Repo 'Annali' sync state transition from 'synchronized' to 'committing'.
[12/24/23 19:06:11] All events are processed for repo 8df1e451-de60-4dc9-904c-b83df88828d1.
[12/24/23 19:06:11] Repo 'Annali' sync state transition from 'committing' to 'initializing'.
(I have replaced the hostname in the logs with xxx for security reasons)
The client shows for hours the animated “progress” circle animation without showing any libraries.
Any ideas why Seafile is stuck?
