The database issue is already discussed here: https://github.com/haiwen/seahub/pull/5073
Is there any fix yet for the download of .zip files with the golang file server discussed earlier in this thread?
With option āuse_go_fileserver = trueā big ISO files (5.5 GB) after upload and download changes HASH. Files are broken.
Without this option the same files uploaded and downloaded well.
Did you try it once or multiple times? On which hardware? Using which upload method (web, client, webdav)?
Multiple times. Two different ISO file. Upload via web.
Ubuntu Server 18.04.4 LTS
You said this :
For me, it was this :
export PYTHONPATH=${INSTALLPATH}/seafile/lib/python3.6/site-packages:${INSTALLPATH}/seahub:${INSTALLPATH}/seahub/thirdpart:$PYTHONPATH
does Open Cloud Mesh fully implemented in this release ?
I administrate 10 Seafile community servers, having OCM working will save us so much time.
Thanks again for this great piece of software.
OCM between Seafile servers works for the web interface. But syncing and seadrive doesnāt work with OCM yet.
We tested locally but cannot reproduce your issue. Have you check for error messages in fileserver.log on the server? Have you run fsck on the library?
Hello here !
Iām currently trying to install SeaFile 9.0.2 on a Raspberry Pi 3, running with Buster.
I followed steps found in a tutorial online (medium dot com, not allowed to add linksā¦).
Seafile server itself seems to be working fine, but my issue occurs when launching seahub. It seems my problem is kind of similar to the ones described here, but I found another older subject on this forum which exactly what I have (post ID is 12441, again canāt add links hereā¦).
Unfortunately, none of the workarounds worked for me
Here is the log I get when I run seahub with start-fastcgi mode:
Starting seahub (fastcgi) at 127.0.0.1:8000 ...
File "/seafile/seafile-server-9.0.2/seahub/seahub/avatar/models.py", line 23, in <module>
from PIL import Image
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/PIL/Image.py", line 89, in <module>
from . import _imaging as core
ImportError: libopenjp2.so.7: cannot open shared object file: No such file or directory
File "/seafile/seafile-server-9.0.2/seahub/manage.py", line 10, in <module>
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/django/core/management/__init__.py", line 419, in execute_from_command_line
utility.execute()
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/django/core/management/__init__.py", line 395, in execute
django.setup()
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/django/__init__.py", line 24, in setup
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/django/apps/registry.py", line 114, in populate
app_config.import_models()
File "/seafile/seafile-server-9.0.2/seahub/thirdpart/django/apps/config.py", line 301, in import_models
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/seafile/seafile-server-9.0.2/seahub/seahub/avatar/models.py", line 26, in <module>
import Image
ModuleNotFoundError: No module named 'Image'
Error:Seahub failed to start.
Could anybody help me with this ?
Thanks a lot in advance !
Brice
Hi !
I went for a little digging into seahub.sh script.
At the line where PYTHONPATH is set, there is a link to a folder called lib64, which does not exist in SeaFile release for Raspberry Pi (architecture ARMV7 in my case).
So I modified the seahub.sh script to call for
${INSTALLPATH}/seafile/lib/python3.7/site-packages
instead of
${INSTALLPATH}/seafile/lib64/python3/site-packages
Now my issue is the following:
File "/seafile/seafile-server-9.0.2/check_init_admin.py", line 19, in <module>
from seaserv import ccnet_api
ModuleNotFoundError: No module named 'seaserv'
Which is kind of normal as the script creates a PYTHONPATH environment variable that does not include a path to embedded Python libraries.
Then Iām guessing that there is something wrong with Python version or modules versionsā¦
I also renamed PIL and Crypto in thirdpart folder of seahub as mentionned somewhere on this forum, which seems to have no effect in my case.
Any clue ?
Thanks !
Hi!
I eventually got it working !
I was missing libopenjp2-7, so after installing it it worked !
Then to sum up the only issue I had was the wrong path in PYTHONPATH setting in seahub.sh.
It is pointing to lib64 folder but it is not present. By changing the path to point to lib folder instead of lib64, it works.
Hope this can be usefull to others
Have a great day!
Brice
There was a announcement of the Raspberry Pi here. The Seafile Server is absolutely the same source code than the amd64 version, but the built script is another. Therefore, could you pls list the contents of /home/seafile/seafile-server-9.0.2/seafile/lib, /home/seafile/seafile-server-9.0.2/seafile/lib/python3 and /home/seafile/seafile-server-9.0.2/seafile/lib/python3.* ?
Thanks.
Iāll try repeat after fsckā¦
Raspberry pie 4B 8GB/
Ubuntu Server 20.04.3 64Bit
seafile-server-9.0.2-focal-arm64v8l. tar. gz
There is no need to modify PYTHONPATH. The lib64 directory has no effect. It seems that Python 3.8 problems caused by MySQLdb support. The MySQLdb directory is incorrectly brought in. Delete or modify this directory to run seahub.sh normally.
#mv /opt/seafile/seafile-server-9.0.2/seahub/thirdpart/MySQLdb MySQLdb.old
you need to install the libmemcached-dev package. Otherwise, the installation of pylibmc dependency package will report an error.
apt-get install libmemcached-dev -y
Seafile 9.0.10 + Ubuntu 18 or Ubuntu 20. Bug still exists.
Test file P03093_001_spp-Gen8.1-SPPGen81.4.iso (SPP for ProLiant Gen8) 5.44 GB MD5 Checksum: 064177d26c939f8dc60c6aefa0799bcf.
After upload and download via web interface MD5 Checksum changed.
fsck running every week. Ubuntu updated from 18 to 20. Seafile Upgraded from 9.0.2 to 9.0.9 and 9.0.10.
Hi @ovelissimo, can you try upgrading to the latest version 10.0. The version 9.0 of go fileserver should have a chunking bug, which could cause the file contents to change.
Seafile 10.0.1. Bug still exists.
