What’s the trick to getting this working on 16.04? If I set up as per the seafile manual I get an unhandled exception on the web page. If I remove the entry from seahub_settings.py then seafile works fine.
The manual is either missing some vital steps (possibly around nginx or apache configuration) or libreoffice docker collabora integration doesn’t work.
Very poorly written manual.
