When i upgrade and add tag 7.1.3 i get this errors:
*** Running /etc/my_init.d/01_create_data_links.sh…,
*** Booting runit daemon…,
*** Runit started as PID 25,
*** Running /scripts/start.py…,
[04/24/2020 16:47:34][upgrade]: The container was recreated, running minor-upgrade.sh to fix the media symlinks,
[04/24/2020 16:47:34][upgrade]: Running script /opt/seafile/seafile-server-7.0.5/upgrade/minor-upgrade.sh,
[2020-04-24 16:47:34] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.,
Traceback (most recent call last):,
File “/scripts/start.py”, line 86, in ,
main(),
File “/scripts/start.py”, line 58, in main,
check_upgrade(),
File “/scripts/upgrade.py”, line 129, in check_upgrade,
fix_media_symlinks(current_version),
File “/scripts/upgrade.py”, line 80, in fix_media_symlinks,
run_minor_upgrade(current_version),
File “/scripts/upgrade.py”, line 84, in run_minor_upgrade,
run_script_and_update_version_stamp(minor_upgrade_script, current_version),
File “/scripts/upgrade.py”, line 60, in run_script_and_update_version_stamp,
replace_file_pattern(script, ‘read dummy’, ‘’),
File “/scripts/utils/init.py”, line 295, in replace_file_pattern,
with open(fn, ‘r’) as fp:,
FileNotFoundError: [Errno 2] No such file or directory: ‘/opt/seafile/seafile-server-7.0.5/upgrade/minor-upgrade.sh’,
*** /scripts/start.py exited with status 1.,
*** Shutting down runit daemon (PID 25)…,
*** Running /etc/my_init.post_shutdown.d/10_syslog-ng.shutdown…,
*** Killing all processes…,
