Seafile Docker upgrade from 8.0.7fails
Docker Seafile 8.0.7 is running fine.
Upgrade to 8.0.7-1 runs fine.
Upgrade to any later version (9.0.0, latest) fails with error messages in the container log.
*** Booting runit daemon...
*** Runit started as PID 25
2023-05-15 10:22:11 Waiting Nginx
2023-05-15 10:22:12 Nginx ready
2023-05-15 10:22:12 This is a idle script (infinite loop) to keep container running.
[05/15/2023 10:22:12][upgrade]: The container was recreated, start fix the media symlinks
mv: cannot stat '/opt/seafile/seafile-server-8.0.7/seahub/media/avatars/*': No such file or directory
[2023-05-15 10:22:12] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
  File "/scripts/start.py", line 86, in <module>
    main()
  File "/scripts/start.py", line 58, in main
    check_upgrade()
  File "/scripts/upgrade.py", line 95, in check_upgrade
    fix_media_symlinks()
  File "/scripts/upgrade.py", line 79, in fix_media_symlinks
    call('mv -n %s/* %s' % (avatars_dir, dst_avatars_dir))
  File "/scripts/utils.py", line 70, in call
  File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
subprocess.CalledProcessError: Command 'mv -n /opt/seafile/seafile-server-8.0.7/seahub/media/avatars/* /shared/seafile/seahub-data/avatars' returned non-zero exit status 1.
Any ideas?
Thanks
Manfred
got the same error now with upgrading from 11.0.6 to 11.0.8. What is the solution?
Edit:
Fixed. While recreating the container its important to change the env flag to the right version. I think everyone will encounter this issue in some case. Is it possible to abandoned this flag?
Hi Maroon,
thanks for the info. Setting the env value for SEAFILE_VERSION to the version to upgrade to (9.0.0) the issue is solved.
Like you mentioned in thread https://forum.seafile.com/t/cant-upgrade-from-11-0-6-to-11-0-8-seahub-media-avatars-no-such-file-or-directory/19692
