You can download it from https://download.seafile.com/d/2a6ebdc224/
Changelog for this version:
- Add shibboleth support
- Show a dialog notify the client is downloading file list from the server during initialisation
- Show transfer rate
- [fix] Fix a bug that lead to the file modification time to be empty
- [fix] Fix a bug that lead to files not be uploaded
The following issues are not fixed yet:
- Seafile Drive client still using the old icons from Seafile Syncing client, which will lead to confusing is you are using both.
- No notifications when moving files from one library to another library
- Misleading error message when try to delete a read-only file
- Only S: can be used for drive letter
For more information on Drive client, please check: Seafile Drive client is ready for testing!
