It’s less confusing than having one of you libraries change name because someone shared with you a library with the same name. Shared libraries with similar/equal names generate conflicts with the Drive client. I’d rather have consistency than intuitiveness, once you learn the pattern you shouldn’t have any problems.
@daniel.pan error on seadrive 0.91 while executing virus scan with kaspersky
in seadrive_gui log
[05/02/18 14:09:39] unknown type of seadrive event file-download.stop
[05/02/18 14:09:40] unknown type of seadrive event file-download.stop
[05/02/18 14:09:41] unknown type of seadrive event file-download.stop
[05/02/18 14:09:42] unknown type of seadrive event file-download.stop
[05/02/18 14:09:43] unknown type of seadrive event file-download.stop
[05/02/18 14:09:44] unknown type of seadrive event file-download.stop
[05/02/18 14:09:45] unknown type of seadrive event file-download.stop
[05/02/18 14:09:46] unknown type of seadrive event file-download.stop
[05/02/18 14:09:47] unknown type of seadrive event file-download.stop
[05/02/18 14:09:48] unknown type of seadrive event file-download.stop
Is this related to kasperky ?
regards
Thanks for the suggestions. The right click menu of open file path/open file will be added in the next release.
Switched back to 0.8.6 because many links and scripts which I’ve hardcoded the drive-letter with path are confused. As standard user, I use it only for own machines don’t share anything - so don’t need this three classification.
This “My Libraries” folder just broke all our referenced drawing files, I’m rolling back to 0.8.6 until this becomes optional.
The BETA tag is there just so you can’t complain about updates breaking layouts.
I will chip in here. I realize it is beta, so not a complaint, just feedback. It would be helpful to be able to have an option to go back to the previous flat structure. I understand the rationale behind this change, but at least for myself, I liked Drive because it kept things simpler for my users. One less step to get to what they need, especially as the bulk of them don’t organize things based on what is shared, what isn’t, etc.
