i’m currently running v13.0.9 but this was happening in v12.0.14 too.
i also have an NFS share mounted at /shared inside the seafile container, could that be the cause?
seafile-1 | *** Running /etc/my_init.d/01_create_data_links.sh...
seafile-1 | rm: cannot remove '/var/log': Directory not empty
seafile-1 | *** Booting runit daemon...
seafile-1 | *** Runit started as PID 19
seafile-1 | *** Running /scripts/enterpoint.sh...
seafile-1 | 2025-09-09 19:17:40 Nginx ready
seafile-1 | 2025-09-09 19:17:40 This is an idle script (infinite loop) to keep container running.
seafile-1 | [2025-09-09 19:17:40] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
seafile-1 | [09/09/2025 19:17:40][upgrade]: The container was recreated, start fix the media symlinks
seafile-1 | mv: not replacing '/shared/seafile/seahub-data/avatars/default-non-register.jpg'
seafile-1 | mv: not replacing '/shared/seafile/seahub-data/avatars/default.png'
seafile-1 | mv: not replacing '/shared/seafile/seahub-data/avatars/groups'
seafile-1 | rm: cannot remove '/opt/seafile/seafile-server-13.0.9/seahub/media/avatars': Directory not empty
seafile-1 | Traceback (most recent call last):
seafile-1 | File "/scripts/start.py", line 94, in <module>
seafile-1 | main()
seafile-1 | File "/scripts/start.py", line 61, in main
seafile-1 | check_upgrade()
seafile-1 | File "/scripts/upgrade.py", line 120, in check_upgrade
seafile-1 | fix_media_symlinks()
seafile-1 | File "/scripts/upgrade.py", line 105, in fix_media_symlinks
seafile-1 | call('rm -rf %s' % avatars_dir)
seafile-1 | File "/scripts/utils.py", line 71, in call
seafile-1 | return subprocess.check_call(*a, **kw)
seafile-1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
seafile-1 | File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
seafile-1 | raise CalledProcessError(retcode, cmd)
seafile-1 | subprocess.CalledProcessError: Command 'rm -rf /opt/seafile/seafile-server-13.0.9/seahub/media/avatars' returned non-zero exit status 1.
here’s an alternate run where i’ve cleared out the contents of the avatars folder
seafile-1 | 2025-09-09 19:42:45 Nginx ready
seafile-1 | 2025-09-09 19:42:45 This is an idle script (infinite loop) to keep container running.
seafile-1 | [2025-09-09 19:42:45] Skip running setup-seafile-mysql.py because there is existing seafile-data folder.
seafile-1 | [09/09/2025 19:42:45][upgrade]: The container was recreated, start fix the media symlinks
seafile-1 | mv: cannot remove '/opt/seafile/seafile-server-13.0.9/seahub/media/avatars/groups': Invalid argument
seafile-1 | main()
