Following the “Deploying Seafile with Docker” (https:// download. seafile. com/published/seafile-manual/docker/deploy%20seafile%20with%20docker.md)
guide, I have set up the seafile-mc container using the following docker-compose.yml:
version: ‘2.0’
db:
image: mariadb:10.1
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=***** # Requested, set the root’s password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /sharedfolders/AppData/seafile-mysql:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-netmemcached:
image: memcached:1.5.6
entrypoint: memcached -m 256
networks:
- seafile-netseafile:
- “80:80”
# - “443:443” # If https is enabled, cancel the comment.
- /sharedfolders/AppData/Seafile:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=***** # Requested, the value shuold be root’s password of MySQL service.
- TIME_ZONE=Europe/London # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=myemail@gmail. com # Specifies Seafile admin user, default is ‘me@example.com’.
- SEAFILE_ADMIN_PASSWORD=***** # Specifies Seafile admin password, default is ‘asecret’.
- SEAFILE_SERVER_HOSTNAME=my. server. org # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-netnetworks:
seafile-net:
All is well, and I am able to access the web server both locally and externally. But then I want to secure the server so I do the following:
- Set “SEAFILE_SERVER_LETSENCRYPT=true”
- Uncomment “443:443”
And the server no longer works; there is no response either from my. server. org, https:// my. server. org, or locally (within my LAN or from the host machine). The same happens even if I point SERVICE_URL in ccnet.conf and FILE_SERVER_ROOT seahub_settings.py to https. There don’t seem to be any errors in the Docker logs, and the container seems to have happily processed the Let’s Encrypt certificate.
What am I missing and can anybody help? Thank you!
