I created a container with seafile on Ubuntu and I would like to make a reverse proxy with https on Apache.
This is my docker-compose and apache setup
version: '2.0'
db:
image: mariadb:10.11
container_name: seafile-mysql
- MYSQL_ROOT_PASSWORD=db_dev # Requested, set the root's password of MySQL service.
- MYSQL_LOG_CONSOLE=true
- /opt/seafile-mysql/db:/var/lib/mysql # Requested, specifies the path to MySQL data persistent store.
networks:
- seafile-net
memcached:
image: memcached:1.6.18
entrypoint: memcached -m 256
networks:
- seafile-net
seafile:
- "8001:80"
- "8082:8082" # If https is enabled, cancel the comment.
- /opt/seafile-data:/shared # Requested, specifies the path to Seafile data persistent store.
- DB_HOST=db
- DB_ROOT_PASSWD=db_dev # Requested, the value should be root's password of MySQL service.
- TIME_ZONE=Etc/UTC # Optional, default is UTC. Should be uncomment and set to your local time zone.
- SEAFILE_ADMIN_EMAIL=email@gmail.com # Specifies Seafile admin user, default is 'me@example.com'.
- SEAFILE_ADMIN_PASSWORD=password # Specifies Seafile admin password, default is 'asecret'.
- SEAFILE_SERVER_HOSTNAME=127.0.0.1 # Specifies your host name if https is enabled.
depends_on:
- db
- memcached
networks:
- seafile-net
networks:
seafile-net:
# seafile fileserver
ProxyPass /seafhttp http://www.siteDomain.com:8001
ProxyPassReverse /seafhttp http://www.siteDomain.com:8001
# seahub
ProxyPreserveHost On
ProxyPass /seafile http://www.siteDomain.com:8001/seafile
ProxyPassReverse /seafile http://www.siteDomain.com:8001/seafile
When I open the browser after logging in I only have a blank page with the writing that the page was not found.
Where am I wrong?
I’ve already seen other posts but I can’t solve it
thank you all
