This is a maintenance release with the following fixes:
- Improve performance of file search
- [fix] Fix copy files larger than 2GB via seaf-fuse (community edition doesn’t have this bug)
- Show 403 error when visit share link if share link creator no longer has access permission to library.
- [API] Add api for uploading file via upload share link.
- [API] Support search file/folder in a specific library and folder via api.
- [fix] Fix a bug in folder renaming operation list on activities page.
- [fix] Fix a bug when creating personal/group wiki.
- [fix] Fix a bug when searching specific extension file.
- [fix] Fix a bug in Two-Factor Authentication.
- [fix] Fix bug when getting encrypted library history.
- [fix] Fix UI bug of “New Library” and “More” button.
- [fix] Fix bug of using truncated image file as avatar.
- Change value of per_page parameter to 10 when search file via api.
- Support indexing files in background after file uploading via API
- Add user clean library trash event to activities
- Use inner fileserver url to save file when edit office via OOS.
