This is a maintenance release with the following fixes and updates:
- [fix] Fix Zip download multiple files
- [fix] Fix a bug in “System Admin -> Logs -> File Update -> details”
- [fix] Fix there is an extra history item for newly created docs/pptx
- [fix] Fix a bug in traffic statistics
- [fix] Fix file modification report email are not sent out
- Support show department libraries in fuse
- Add expiring date for upload link
- Add search feature in pubished libraries for anonymous users
Hi Daniel,
Did you added back the internal link as we discussed before ? @rdb and me would be glad to.
Regards
It will be added back in the next release.
After upgrading my test server from 6.3.14 to 7.0.5 I realised, that my logo on the login screen is distorted.
old:
<img src="/media/custom/mylogo.png" title="MyShare" alt="logo" width="160" height="40" class="login-panel-logo">
new:
<img src="/media/custom/mylogo.png" title="MyShare" alt="logo" width="256" height="40" class="login-panel-logo">
The cause is the file seahub/seahub/templates/registration/login.html where the width parameter of the logo is missing:
old:
$('.login-panel-outer-container').prepend($($('#logo').html()).attr({'width': 160, 'height': 40}).addClass('login-panel-logo'));
new:
$('.login-panel-outer-container').prepend($($('#logo').html()).attr({'height': 40}).addClass('login-panel-logo'));
Can this be fixed? Or can the logo width be configured somewhere?
Thanks.
Dirk
rdb
5
