We have trubles with Seafile PRO server to 8.0.3 in combination with SeaDrive (different versions). Everything seems working but SeaDrive clients start throwing “Internal server error” and not sync file updates. I said to employees to let PCs running over weekend to let it sync without touching but without effect. Standard client and web interface works.
I did upgrade on two machines to latest SeaDrive (2.0.13) and result is it never sync initial files tree.
Any suggestion? I tried to see server logs and SeaDrive logs. On server no error … on client just same like notification “Internal server error”.
We need to fix that really fast because, nobody can work.
Actually it affects both versions. However we think it’s best to not affect 7.1.x versions by default. So we’ll change the default behavior to not check file numbers in the next 7.1.x version.
