Seafile pro edition 10.0.9 is ready! ARM64 is also supported now
This is a maintenance release with following improvements and fixes:
  • Add an option (library_file_limit in seafile.conf) to support setting the maximum number of files in a single library
  • [fix] Support for virus scan in golang file server when uploading files via upload links
  • Some UI fixes and improvements
  • Improve script clear_invalid_repo_data.py
ARM64 is also supported now. When you pull docker image in ARM64 based system, the corresponding docker image for ARM64 will be downloaded.
good news. :+1:
