Update Python dependencies and support Ubuntu 22.04 and Debian 11
Add a new notification server
Enable limiting download/upload speed for a certain role
Simplified configuration for SAML authentication
Some improvements of multi-tenancy mode, like a team admin can set team logo, support each team to have its own SAML login
Watch and get notifications for libraries
Support a user to generate multiple share links for a single file/folder
The notification server enables desktop syncing and drive clients to get notification of library changes immediately using websocket. There are two benefits:
Reduce the time for syncing new changes to local
Reduce the load of the server as periodically pulling is removed. There are significant reduction of load when you have 1000+ clients.
The notification server works with Seafile syncing client 9.0+ and drive client 3.0+.
2 problems identified with this new version (running from the CentOS tarball on AlmaLinux 8 x86_64)
In the CentOS tarball, the python lib dir is for python2.7 instead of python3 (dir seafile/lib64/python2.7 instead of seafile/lib64/python3). A simple symlink work around this
I can’t get the ES indexation to work. Running ES 8.7.1, I wiped my existing index, but when I try to update the index I get this
Updating search index, this may take a while...
05/21/2023 11:49:26 [INFO] seafes:210 main: storage: using filesystem storage backend
05/21/2023 11:49:26 [INFO] seafes:212 main: index office pdf: True
05/21/2023 11:49:26 [INFO] elastic_transport.transport:336 perform_request: HEAD http://localhost:9200/repo_head [status:404 duration:0.006s]
05/21/2023 11:49:26 [INFO] elastic_transport.transport:336 perform_request: PUT http://localhost:9200/repo_head [status:200 duration:0.241s]
05/21/2023 11:49:26 [INFO] elastic_transport.transport:336 perform_request: PUT http://localhost:9200/repo_head/_mapping [status:200 duration:0.062s]
05/21/2023 11:49:26 [INFO] elastic_transport.transport:336 perform_request: POST http://localhost:9200/repo_head/_refresh [status:200 duration:0.012s]
05/21/2023 11:49:26 [INFO] elastic_transport.transport:336 perform_request: HEAD http://localhost:9200/repofiles [status:404 duration:0.003s]
05/21/2023 11:49:27 [INFO] elastic_transport.transport:336 perform_request: PUT http://localhost:9200/repofiles [status:200 duration:0.641s]
05/21/2023 11:49:27 [INFO] elastic_transport.transport:336 perform_request: PUT http://localhost:9200/repofiles/_mapping [status:200 duration:0.033s]
05/21/2023 11:49:27 [INFO] elastic_transport.transport:336 perform_request: POST http://localhost:9200/repofiles/_refresh [status:200 duration:0.005s]
05/21/2023 11:49:27 [INFO] seafes:161 start_index_local: Index process initialized.
05/21/2023 11:49:27 [INFO] seafes:45 run: starting worker0 worker threads for indexing
05/21/2023 11:49:27 [INFO] seafes:45 run: starting worker1 worker threads for indexing
05/21/2023 11:49:27 [ERROR] seafes:113 get_repo_id_commit_id: tuple indices must be integers or slices, not str
05/21/2023 11:49:27 [ERROR] seafes:58 run: Error: tuple indices must be integers or slices, not str
05/21/2023 11:49:29 [DEBUG] seafes:94 thread_task: Queue is empty, worker0 worker threads stop
05/21/2023 11:49:29 [DEBUG] seafes:94 thread_task: Queue is empty, worker1 worker threads stop
05/21/2023 11:49:29 [INFO] seafes:119 thread_task: worker0 worker updated at 2023-05-21 11:49 time
05/21/2023 11:49:29 [INFO] seafes:124 thread_task: worker0 worker get 0 error
05/21/2023 11:49:29 [INFO] seafes:119 thread_task: worker1 worker updated at 2023-05-21 11:49 time
05/21/2023 11:49:29 [INFO] seafes:124 thread_task: worker1 worker get 0 error
05/21/2023 11:49:29 [INFO] seafes:38 clear_worker: All worker threads has stopped.
05/21/2023 11:49:29 [INFO] seafes:164 start_index_local:
Index updated, statistic report:
05/21/2023 11:49:29 [INFO] seafes:165 start_index_local: [commit read] 0
05/21/2023 11:49:29 [INFO] seafes:166 start_index_local: [dir read] 0
05/21/2023 11:49:29 [INFO] seafes:167 start_index_local: [file read] 0
05/21/2023 11:49:29 [INFO] seafes:168 start_index_local: [block read] 0
And none of my files are returned in search results. Files uploaded are also not being indexed. Communication from Seafile to ES seems fine, as I can see this while searching
mai 21 11:51:36 alma8 python[12925]: 2023-05-21 09:51:36,575 [DEBUG] urllib3.connectionpool:228 _new_conn Starting new HTTP connection (1): localhost:9200
mai 21 11:51:36 alma8 python[12925]: 2023-05-21 09:51:36,581 [DEBUG] urllib3.connectionpool:456 _make_request http://localhost:9200 "HEAD /repofiles HTTP/1.1" 200 0
mai 21 11:51:36 alma8 python[12925]: 2023-05-21 09:51:36,582 [INFO] elastic_transport.transport:336 perform_request HEAD http://localhost:9200/repofiles [status:200 duration:0.008s]
mai 21 11:51:36 alma8 python[12925]: 2023-05-21 09:51:36,590 [DEBUG] urllib3.connectionpool:456 _make_request http://localhost:9200 "POST /repofiles/_search?_source_includes=repo,path,filename,is_dir HTTP/1.1" 200 160
mai 21 11:51:36 alma8 python[12925]: 2023-05-21 09:51:36,590 [INFO] elastic_transport.transport:336 perform_request POST http://localhost:9200/repofiles/_search?_source_includes=repo,path,filename,is_dir [status:200 duration:0.007s]
The problem was the SQLAlchemy version in my venv (which was from the 2.x branch). Downgrading to the 1.4.3 version (just like the Docker image) made it.
