Since version 7.1.x there is no more generic install, only Ubuntu and CentOS versions.
To upgrade my Seafile pro which is installed on Debian, should I stick to the Ubuntu version ?
Thanks !
(I know, this might sound like a stupid question, but I would like to be sure…)
The PR only solve the front-end issue related to video generation. If the user doesn’t install the necessary libraries, it will generate errors in the server side.
Correctly installing the libraries in different platforms is not an easy task and sometimes causing high CPU usage issue. We don’t have a plan to add this feature back.
This is community edition only problem. We will solve the problem in 7.1.4 for CE.
Are there any change in the API ?
I upgraded from 7.0.10 to 7.1.4 without any problem.
However, if I perform a Get Organizations request I only get 25 of them when I should receive 40…
Any idea about what happens ?
And still no Max User Number…
Thanks for the release !
I couldn’t wait for 7.1.4 because on another thread @Jonathan mentioned that this release would officially support migrating library from one storage backend to another. Any update on this ? Because I can’t figure out how to migrate a single library from a FS backend to another FS backend.
Link to the thread : forum.seafile .com/t/migrate-a-single-library-to-another-storage-backend/7821/7
