Seafile pro edition v12.0 is ready for testing, with both x64 and arm64 versions.
The changelog:
- A redesigned Web UI
- SeaDoc is now stable, providing online notes and documents feature
- A new wiki module
- A new trash mechanism, that deleted files will be recorded in database for fast listing
- The password strength level is now calculated by algorithm. The old USER_PASSWORD_MIN_LENGTH, USER_PASSWORD_STRENGTH_LEVEL is removed. Only USER_STRONG_PASSWORD_REQUIRED is still used.
- ADDITIONAL_APP_BOTTOM_LINKS is removed. Because there is no buttom bar in the navigation side bar now.
- SERVICE_URL and FILE_SERVER_ROOT are removed. SERVICE_URL will be calculated from SEAFILE_SERVER_PROTOCOL and SEAFILE_SERVER_HOSTNAME in
.envfile. ccnet.confis removed. Some of its configuration items are moved from.envfile, others are read from items inseafile.confwith same name.- For security reason, WebDAV no longer support login with LDAP account, the user with LDAP account must generate a WebDAV token at the profile page
- [File tags] The current file tags feature is deprecated. We will re-implement a new one in version 13.0 with a new general metadata management module.
- For ElasticSearch based search, full text search of doc/xls/ppt file types are no longer supported. This enable us to remove Java dependency in Seafile side.
Note, seasearch support is not ready yet. We are still working on it.
