Hey guys,
Got my Seafile Pro Docker setup with S3 back-end and running into few issues.
- Libraries get initially created with S3, but then I lose access after certain period of time and error messages start showing up below.
- Only way to fix this is to set S3 buckets as public.
- Even creating buckets from IAM user used within Seafile config returns the error messages below.
- IAM user has full S3 access.
- By default AWS S3 owner / creator should have full access, but error message shows up not long after creation. https://docs.aws.amazon.com/AmazonS3/latest/dev/s3-access-control.html
Have any of you guys ran into these types of errors?
Thanks,
AccessDeniedAccess Denied7E0B4570E33D4FD0g93/osd6PmSTQN4WtfBg0zlGb5snI41DQ1hwo2OJmYakYd+Kz7hYHeEMcISOVhwn409aTCPB7j4=
Dec 18 04:28:43 73af929c3935 seaf-server[151]: repo-mgr.c(6309): Failed to add commit.
Dec 18 04:28:43 73af929c3935 2018-12-18 04:28:43,527 [ERROR] django.request:135 handle_uncaught_exception Internal Server Error: /api2/repos/public/
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/core/handlers/exception.py”, line 41, in inner
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/core/handlers/base.py”, line 249, in _legacy_get_response
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/core/handlers/base.py”, line 187, in _get_response
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/core/handlers/base.py”, line 185, in _get_response
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/views/decorators/csrf.py”, line 58, in wrapped_view
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/django/views/generic/base.py”, line 68, in view
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/seahub/api2/base.py”, line 23, in dispatch
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/rest_framework/views.py”, line 466, in dispatch
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/seahub/api2/base.py”, line 20, in handle_exception
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/thirdpart/rest_framework/views.py”, line 463, in dispatch
File “/opt/seafile/seafile-pro-server-6.3.7/seahub/seahub/api2/views.py”, line 1059, in post
repo_desc, username, passwd)
File “/opt/seafile/seafile-pro-server-6.3.7/seafile/lib/python2.7/site-packages/seaserv/api.py”, line 89, in create_repo
return seafserv_threaded_rpc.create_repo(name, desc, username, passwd, storage_id)
File “/opt/seafile/seafile-pro-server-6.3.7/seafile/lib/python2.7/site-packages/pysearpc/client.py”, line 112, in newfunc
return fret(ret_str)
File “/opt/seafile/seafile-pro-server-6.3.7/seafile/lib/python2.7/site-packages/pysearpc/client.py”, line 25, in _fret_string
raise SearpcError(dicts[‘err_msg’])
SearpcError: Failed to add commit
