Hey,
I’ve tried everything and I do not know what’s wrong.
After updating (I had some problems with that and I described them here Seafile Pro Server upgrade 6.3.13 -> 7.0.3. Libraries problem) Seafile Pro Server from version 6.3.13 to 7.0.3. the search service does not work for me. I was hoping it was because the new version but no - after updating to 7.0.4 nothing has changed.
Please, help me fix it.
Command:
./pro.py search --clear
Result:
Delete search index, this may take a while...
07/05/2019 18:52:28 [INFO] root:208 main: storage: using filesystem storage backend
07/05/2019 18:52:28 [INFO] root:210 main: index office pdf: True
File "/usr/lib64/python2.7/runpy.py", line 162, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/lib64/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/seafes/index_local.py", line 268, in <module>
main()
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/seafes/index_local.py", line 212, in main
args.func()
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/seafes/index_local.py", line 173, in delete_indices
if es.indices.exists(idx):
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/elasticsearch/client/utils.py", line 73, in _wrapped
return func(*args, params=params, **kwargs)
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/elasticsearch/client/indices.py", line 224, in exists
params=params)
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/elasticsearch/transport.py", line 312, in perform_request
status, headers, data = connection.perform_request(method, url, params, body, ignore=ignore, timeout=timeout)
File "/opt/seafile/seafile-pro-server-7.0.4/pro/python/elasticsearch/connection/http_urllib3.py", line 124, in perform_request
raise ConnectionError('N/A', str(e), e)
elasticsearch.exceptions.ConnectionError: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f4772096850>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f4772096850>: Failed to establish a new connection: [Errno 111] Connection refused)
Command:
./pro.py search --update
Result:
Updating search index, this may take a while...
07/05/2019 18:52:39 [INFO] root:208 main: storage: using filesystem storage backend
07/05/2019 18:52:39 [INFO] root:210 main: index office pdf: True
07/05/2019 18:52:39 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f550d43d390>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f550d43d390>: Failed to establish a new connection: [Errno 111] Connection refused).
The entire directory belongs to the seafile user:
drwx------. 3 seafile seafile 73 Jul 5 18:50 ccnet
drwx------. 2 seafile seafile 161 Jul 4 12:10 conf
drwx------. 2 seafile seafile 6 Feb 25 18:25 Desktop
drwxr-xr-x. 2 seafile seafile 100 Oct 30 2018 installed
drwxr-xr-x. 3 seafile seafile 4096 Jul 2 00:01 logs
drwxr-xr-x. 2 seafile seafile 105 Jul 5 18:50 pids
drwx------. 2 seafile seafile 6 Jun 18 12:38 pro-data
drwx------. 9 seafile seafile 119 Oct 30 2018 seafile-data
drwxr-xr-x. 10 seafile seafile 4096 Jul 5 07:36 seafile-pro-server-7.0.4
lrwxrwxrwx. 1 seafile seafile 24 Jul 5 18:50 seafile-server-latest -> seafile-pro-server-7.0.4
drwxr-xr-x. 5 seafile seafile 52 Jul 3 12:00 seahub-data
index.log:
07/05/2019 18:00:48 [INFO] root:208 main: storage: using filesystem storage backend
07/05/2019 18:00:48 [INFO] root:210 main: index office pdf: True
07/05/2019 18:00:48 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f381b68b410>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f381b6$
07/05/2019 18:10:48 [INFO] root:208 main: storage: using filesystem storage backend
07/05/2019 18:10:48 [INFO] root:210 main: index office pdf: True
07/05/2019 18:10:48 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7feb446c3410>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7feb446$
07/05/2019 18:20:48 [INFO] root:208 main: storage: using filesystem storage backend
07/05/2019 18:20:48 [INFO] root:210 main: index office pdf: True
07/05/2019 18:20:48 [ERROR] seafes:158 start_index_local: Index process init error: ConnectionError(<urllib3.connection.HTTPConnection object at 0x7f5676c45410>: Failed to establish a new connection: [Errno 111] Connection refused) caused by: NewConnectionError(<urllib3.connection.HTTPConnection object at 0x7f5676c$
Of course, since the problem appeared, I have reset the server many times.
