Hallo,
I’ve just upgraded Thunderbird from the latest v59 release to the new v60. Before I was using very frequently the Seafile/SeaLink plugin for Filelink in Thunderbird (https://github.com/szimszon/tb-filelink-seafile) and I really love it. However, this plugin (not developed by Seafile them self) seams to be not compatible anymore with the new Thunderbird version 60. Unfortunately, there is no support anymore for this great plugin so I would expect that the former developers will not release a patch allowing to use the Seafile/SeaLink plugin in more recent versions of Thunderbird anymore. Very bad.
Is here anybody who has observed the same issue with the Seafile/SeaLink plugin in Thunderbird v60? Has anybody an idea how to fix the compatibility problem in TB v60 besides reprogramming the plugin?
After upgrading from TB 59 -> TB 60 I’ve seen the message that the plugin will be stopped after restarting TB. This issue disappeared when I change “extensions.strictCompatibility” from true to false in “about:config”. However, the Seafile/SeaLink plugin still does not work. Next, I’ve reinstalled the plugin (the seafile_for_filelink-0.10.1-tb.xpi file) but when I’ve tried to add the plugin using the attachment/filelink dialog in TB the Seafile/SeaLink option does not pop up.
Any ideas or comments regarding Seafile/SeaLink for Thunderbird?
Hannes
