Then go for pip3 install pillow this will install Pillow for all the users.
I had already done that, of course, to begin with ![]()
pip3 install pillow
Requirement already satisfied: pillow in /usr/local/lib/python3.6/site-packages (7.1.2)
You have something messed up, sorry.
Ok, I will try to do some more investigative work, thanks for helping!
Can you post the error you get starting seahub? the whole error pls.
File "/var/www/seafile/seafile-server-7.1.4/seahub/seahub/avatar/models.py", line 23, in <module>
from PIL import Image
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/PIL/Image.py", line 93, in <module>
from . import _imaging as core
ImportError: cannot import name '_imaging'
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/bin/gunicorn", line 8, in <module>
sys.exit(run())
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/wsgiapp.py", line 58, in run
WSGIApplication("%(prog)s [OPTIONS] [APP_MODULE]").run()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/base.py", line 228, in run
super().run()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/base.py", line 72, in run
Arbiter(self).run()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/arbiter.py", line 58, in __init__
self.setup(app)
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/arbiter.py", line 118, in setup
self.app.wsgi()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/base.py", line 67, in wsgi
self.callable = self.load()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/wsgiapp.py", line 49, in load
return self.load_wsgiapp()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/app/wsgiapp.py", line 39, in load_wsgiapp
return util.import_app(self.app_uri)
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/gunicorn/util.py", line 358, in import_app
mod = importlib.import_module(module)
File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 665, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/var/www/seafile/seafile-server-7.1.4/seahub/seahub/wsgi.py", line 25, in <module>
application = get_wsgi_application()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/django/core/wsgi.py", line 13, in get_wsgi_application
django.setup(set_prefix=False)
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/django/__init__.py", line 27, in setup
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/django/apps/registry.py", line 108, in populate
app_config.import_models()
File "/var/www/seafile/seafile-server-7.1.4/seahub/thirdpart/django/apps/config.py", line 202, in import_models
File "/var/www/seafile/seafile-server-7.1.4/seahub/seahub/avatar/models.py", line 26, in <module>
import Image
ImportError: No module named 'Image'
Possible relations:
- Do you have
memcached? - make a ls -ltr for the /seahub/thirdpart directory
- which rpi OS did you download?
- which OS do you have?
You need python version 3.6 or upwards…
Yeaahh! good catch!
Do you have
memcached?
Yes -
total 444
drwxr-xr-x 8 seafile seafile 4096 Dec 23 03:12 wsgidav
drwxr-xr-x 2 seafile seafile 4096 May 15 04:34 weworkapi
drwxr-xr-x 4 seafile seafile 4096 May 15 04:34 shibboleth
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 future-0.18.2.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 Pillow-7.1.2.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 django_post_office-3.3.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 et_xmlfile-1.0.1.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 openpyxl-2.6.4.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 django_simple_captcha-0.5.12.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 django_ranged_response-0.2.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 21 21:49 pycryptodome-3.9.7.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:37 pytz-2020.1.dist-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:37 pytz
drwxr-xr-x 2 seafile seafile 4096 May 24 13:37 Django-1.11.29.dist-info
drwxr-xr-x 19 seafile seafile 4096 May 24 13:37 django
drwxr-xr-x 10 seafile seafile 4096 May 24 13:37 future
drwxr-xr-x 7 seafile seafile 4096 May 24 13:37 past
drwxr-xr-x 4 seafile seafile 4096 May 24 13:37 libpasteurize
drwxr-xr-x 4 seafile seafile 4096 May 24 13:37 libfuturize
drwxr-xr-x 2 seafile seafile 4096 May 24 13:37 future-0.18.2-py3.6.egg-info
drwxr-xr-x 5 seafile seafile 4096 May 24 13:38 statici18n
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 six-1.15.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 jsonfield2-3.0.3.dist-info
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 jsonfield
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_statici18n-1.9.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_appconf-1.0.4.dist-infodrwxr-xr-x 2 seafile seafile 4096 May 24 13:38 captcha-0.3.dist-info
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 appconf
drwxr-xr-x 5 seafile seafile 4096 May 24 13:38 webpack_loader
drwxr-xr-x 9 seafile seafile 4096 May 24 13:38 post_office
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_webpack_loader-0.7.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_post_office-3.3.0-py3.6.egg-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 setuptools-46.4.0.dist-info
drwxr-xr-x 6 seafile seafile 4096 May 24 13:38 setuptools
drwxr-xr-x 5 seafile seafile 4096 May 24 13:38 pkg_resources
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 gunicorn-20.0.4.dist-info
drwxr-xr-x 7 seafile seafile 4096 May 24 13:38 gunicorn
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 PyMySQL-0.9.3.dist-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:38 pymysql
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 picklefield
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 jdcal-1.4.1.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_picklefield-2.1.1.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 et_xmlfile-1.0.1-py3.6.egg-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:38 et_xmlfile
drwxr-xr-x 21 seafile seafile 4096 May 24 13:38 openpyxl
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 share
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 qrcode-6.1.dist-info
drwxr-xr-x 5 seafile seafile 4096 May 24 13:38 qrcode
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 openpyxl-3.0.3-py3.6.egg-info
drwxr-xr-x 6 seafile seafile 4096 May 24 13:38 formtools
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_formtools-2.2.dist-infodrwxr-xr-x 3 seafile seafile 4096 May 24 13:38 ranged_response
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_ranged_response-0.2.0-py3.6.egg-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 django_simple_captcha-0.5.12-py3.6.egg-info
drwxr-xr-x 12 seafile seafile 4096 May 24 13:38 captcha
drwxr-xr-x 11 seafile seafile 4096 May 24 13:38 rest_framework
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 djangorestframework-3.11.0.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 python_dateutil-2.8.1.dist-info
drwxr-xr-x 6 seafile seafile 4096 May 24 13:38 dateutil
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 chardet-3.0.4.dist-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:38 chardet
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 certifi
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 urllib3-1.25.9.dist-info
drwxr-xr-x 6 seafile seafile 4096 May 24 13:38 urllib3
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 requests-2.23.0.dist-info
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 requests
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 idna-2.9.dist-info
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 idna
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 certifi-2020.4.5.1.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:38 PyJWT-1.7.1.dist-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:38 jwt
drwxr-xr-x 3 seafile seafile 4096 May 24 13:38 bin
drwxr-xr-x 13 seafile seafile 4096 May 24 13:39 Crypto
drwxr-xr-x 2 seafile seafile 4096 May 24 13:40 pycryptodome-3.9.7-py3.6.egg-info
drwxr-xr-x 2 seafile seafile 4096 May 24 13:40 requests_oauthlib-1.3.0.dist-info
drwxr-xr-x 4 seafile seafile 4096 May 24 13:40 requests_oauthlib
drwxr-xr-x 2 seafile seafile 4096 May 24 13:40 oauthlib-3.1.0.dist-info
drwxr-xr-x 6 seafile seafile 4096 May 24 13:40 oauthlib
drwxr-xr-x 6 seafile seafile 4096 May 24 14:00 lxml
drwxr-xr-x 2 seafile seafile 4096 May 24 14:00 lxml-4.5.1-py3.6.egg-info
drwxr-xr-x 3 seafile seafile 4096 May 24 14:00 yaml
drwxr-xr-x 2 seafile seafile 4096 May 24 14:00 PyYAML-5.3.1-py3.6.egg-info
drwxr-xr-x 2 seafile seafile 4096 May 24 14:00 python_pam-1.8.4.dist-info
drwxr-xr-x 2 seafile seafile 4096 May 24 14:00 jsmin-2.2.2-py3.6.egg-info
drwxr-xr-x 3 seafile seafile 4096 May 24 14:00 jsmin
drwxr-xr-x 2 seafile seafile 4096 May 24 14:00 defusedxml-0.6.0.dist-info
drwxr-xr-x 3 seafile seafile 4096 May 24 14:00 defusedxml
drwxr-xr-x 4 seafile seafile 4096 May 24 23:50 seafobj
-rw-r--r-- 1 seafile seafile 34159 May 24 23:54 six.py
-rw-r--r-- 1 seafile seafile 126 May 24 23:54 easy_install.py
-rw-r--r-- 1 seafile seafile 12462 May 24 23:54 jdcal.py
-rw-r--r-- 1 seafile seafile 317 May 24 23:54 requirements.txt
-rw-r--r-- 1 seafile seafile 7556 May 24 23:54 pam.py
drwxr-xr-x 2 seafile seafile 4096 May 31 17:29 __pycache__
drwxr-xr-x 8 seafile seafile 4096 May 31 17:31 registration
drwxr-xr-x 6 seafile seafile 4096 May 31 17:31 constance
drwxr-xr-x 7 seafile seafile 4096 May 31 17:31 termsandconditions
drwxr-xr-x 3 seafile seafile 4096 May 31 18:44 PIL
drwxr-xr-x 2 seafile seafile 4096 May 31 18:44 Pillow-7.1.2-py3.6.egg-info
https://github.com/haiwen/seafile-rpi/releases/download/v7.1.4/seafile-server_7.1.4_pi-stretch-stable.tar.gz -
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
@axstet already give you the hint
update your python
The infos are on the top of the thread.
I already have python 3.6
ls /usr/local/bin/
2to3-3.6 easy_install-3.6 keyring pip2.7 pocketsphinx_batch pydoc3.6 python3.6m python3.7m-config sphinx_cont_seg sphinx_lm_eval
2to3-3.7 easy_install-3.7 pihole pip3 pocketsphinx_continuous pydoc3.7 python3.6m-config pyvenv-3.6 sphinx_fe sphinx_pitch
django-admin idle3.6 pip pip3.6 pocketsphinx_mdef_convert pyjwt python3.7 pyvenv-3.7 sphinx_jsgf2fsg sqlformat
django-admin.py idle3.7 pip2 pip3.7 __pycache__ python3.6 python3.7m sphinx_cepview sphinx_lm_convert virtualenv
make a python -V and you will understand why
I understand that, that points to the default python 2.7, which I don’t think it would be smart to change if the OS assumes that to be v 2.7, no?
You don’t need to, but then you need to setup your seafile and seahub service to use your python >= 3.6 installation.
This is a friendly reminder. Please read the other notes on the top.
Like I said, I do have Python 3.6. What is not clear from the instruction above, sorry!, is then how to force Seafile to use the already available python3.6 executable.
I have read the link you provide, but it’s still unclear.
Should be ok to link python3 to python3.6 or python3.7. What is the output of python3 -V? If not > = 3.6, change link in /usr/bin/. Alternatively read about ‘systemd’ and ‘Environment’ or ‘EnvironmentFile’ option.
I managed to fix the " ModuleNotFoundError: No module named ‘Image’ " error on Raspberry Pi OS Buster Lite by running the following command:
sudo apt install libtiff5
I ended up upgrading my OS to Ubuntu 18.04, which of course broke everything else running on my server, but at least now Seafile uses Python 3.6.
N.B.: Even after the OS upgrade, I had some import errors from seahub, due to missing packages, although I had installed them globally with pip3 prior. Therefore, I reinstalled them ‘locally’ to Seafile by running sudo -u seafile bash -c "pip3 install -U pillow django-pylibmc -t /var/www/seafile/seafile-server-latest/seahub/thirdpart", and that did the trick.
