Seafile Server 7.1.4 for Raspberry Pi is ready! 23.05.2020
Thank you @jobenvil - upgrading with following your detailed instructions worked perfectly for me.
I am also having trouble starting seahub after upgrading to 7.1.4:
  File "/home/seafile/seafile-server-7.1.4/seahub/seahub/avatar/models.py", line 23, in <module>
    from PIL import Image
  File "/home/seafile/seafile-server-7.1.4/seahub/thirdpart/PIL/Image.py", line 93, in <module>
    from . import _imaging as core
ImportError: cannot import name '_imaging' from 'PIL' (/home/seafile/seafile-server-7.1.4/seahub/thirdpart/PIL/__init__.py)
My system:
Python 3.7.3
Kernel: 4.19.66-v7+ armv7l (32 bit)
Distro: Raspbian GNU/Linux 10 (buster)
I installed:
seafile-server_7.1.4_pi-buster-stable.tar.gz
I tried to install Pillow to thridpart:
sudo pip3 install -U pillow -t /var/www/seafile/seafile-server-latest/seahub/thirdpart
I also tried sudo pip3 install pillow and sudo -u seafile pip3 install pillow but nothing helps.
What am I missing out?
This is my second attempt. After failing to run it on Raspian Stretch, I upgraded to Buster and installed 7.1.4_pi-buster-stable. Might there be some leftovers from the stretch attempt? If so, what do I need to clean?
@aveltens Maybe this :point_up_2:
Thanks for the quick response. My understanding is, I do not need the symlink since the directory is already named python3.6 and I did not get any errors regarding such a path issue. Or do I need the link the other way arround then ln -s python3.6 python3.7?
It depends on which os you downloaded. Stretch had the directory /python3.6 and Buster /python3.7. If you still see /python3.6 it means that you have still have installed the Strech version instead of Buster, unless you renamed did earlier.
oh damn, you’re right. My ansible script actually did not download the buster version, but used the cached strech download :man_facepalming:
I added the symlink and now it seams to start without error, BUT it does not seam to reach a started state:
 seahub.service - Seafile hub
   Loaded: loaded (/etc/systemd/system/seahub.service; enabled; vendor preset: enabled)
   Active: activating (start) since Mon 2020-06-01 14:35:11 CEST; 3min 2s ago
Oh never mind, I just forgot to switch back to daemon=True. Everything is back to normal now. Thanks for your help and patience.
Also big thanks for your very detail initial post wich solved serveral of my inital problems / questions. Would be great if such a post is linked from the Release notes on github for the next releases.
Yes, actually there is some warning regarding the official support channel, but it could be explicitedly the indication to go to the forum to see the recomendations.
Sorry for this late answer.
I have commented out the “CACHES” part inside seahub_settings.py now. And it works now (without memcached?). I don’t know, but i think its faster then before. Weird.
Memcached is running. But you could be right. i never understood how memcached works.
Is it recommended to use on Seafile server on Raspberry Pi’s?
~ $ service memcached status
memcached.service - memcached daemon
Loaded: loaded (/lib/systemd/system/memcached.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-05-31 06:10:38 CEST; 1 day 15h ago
Docs: man:memcached(1)
Main PID: 487 (memcached)
Tasks: 10 (limit: 4915)
Memory: 4.2M
CGroup: /system.slice/memcached.service
└─487 /usr/bin/memcached -m 64 -p 11211 -u memcache -l 127.0.0.1
~ $ memcached -V
memcached 1.5.6
Thank you very much for your help! :slightly_smiling_face:
I never used memcached in my installations, because I read somewhere that it was only recommended, if more than 50 people access the webinterface simultaneously. This is not the case for my installations. For updating to 7.1.4 I now had to install the memcached modules (otherwise the upgrade-Script wouldn’t run), but I also noticed that with memcached backend activated in seahub_settings.py the installations were slower than before. So I commented out the memcached Settings in seahub_settings.py and again noticed a speed gain.
I had the same experience. Thanks @Bernie_O to share with us :slight_smile:
Many thanks for this work !
I noticed that, but I was not going to raise an issue, just upgrading my Seafile instance. So I followed the linked upgrade guide, not being aware of relevant info in this place here.
How did you see a slowdown with memcached enabled? You mean slower webui?
I didn’t notice that, but i don’t see real difference in loading ui, with or without memcached.
Maybe its because my device is bit faster? Its an odroid hc1 with armbian buster…
The cache is only for seahub. Yes, a slower webui.
I don’t think this has to do with the performance of devices.
Hi all, the referenced manual is not existing, can you please check @jobenvil ? :slight_smile:
Thanks a lot and a happy new year!
Cheers
HNY! sure @ksbn https://manual.seafile.com/upgrade/upgrade_notes_for_7.1.x/
When I try to start seahub, I get the following error:
./seahub.sh: line 210: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8): No such file or directory
File “/opt/seafile/seafile-server-8.0.3/check_init_admin.py”, line 19, in
from seaserv import ccnet_api
ModuleNotFoundError: No module named ‘seaserv’
Could not find anything on the net :-/
