I was using Debian Jessie and recently upgraded the system to Stretch. I had Seafile client 5.0.1 installed and after the system upgrade the libraries are initially synced (it would begin to download the files) and then immediately unsync a few seconds later. I thought maybe it was a bug with the old Seafile client, so I upgraded to 6.0.0 and I am still having the same problem - I open Seafile and then about 20 seconds later all libraries become unsynced.
I just realized something else. After the folders become unsynced, if I try to resync one of them (choosing a different directory) I get the error:
Failed to add download task:
Transport Error
Looking at my log files, this is what I have:
Applet.log
[12/12/2016 02:21:18 PM]starting ccnet: (“-c”, “/home/mike/.ccnet”)
[12/12/2016 02:21:19 PM]trying to connect to ccnet daemon…
[12/12/2016 02:21:19 PM]connected to ccnet daemon
[12/12/2016 02:21:19 PM]starting seaf-daemon: (“-c”, “/home/mike/.ccnet”, “-d”, “/home/mike/Seafile/.seafile-data”, “-w”, “/home/mike/Seafile”)
[12/12/2016 02:21:20 PM][Rpc Client] connected to daemon
[12/12/2016 02:21:20 PM][MessageListener] connected to daemon
[12/12/2016 02:21:20 PM]Unable to get config value download_limit: Config not exists
[12/12/2016 02:21:20 PM]Unable to get config value upload_limit: Config not exists
[12/12/2016 02:21:20 PM]QString::arg: Argument missing: &Open cloud file browser, Seafile
[12/12/2016 02:21:21 PM][Rpc Client] connected to daemon
[12/12/2016 02:21:22 PM]The latest version is 5.0.1
[12/12/2016 02:21:52 PM][Sea RPC] Bad response: 515 peer down.
[12/12/2016 02:21:52 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:53 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:54 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:55 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:56 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:57 PM][Sea RPC] Bad response: 102 processor is dead.
[12/12/2016 02:21:58 PM][Daemon Mgr] stopping ccnet/seafile daemon
ccnet.log
[12/12/16 14:21:18] ccnet-daemon.c(193): starting ccnet client 6.0.0
[12/12/16 14:21:18] …/common/session.c(132): using config file /home/mike/.ccnet/ccnet.conf
[12/12/16 14:21:18] …/common/session.c(455): socket file exists, delete it anyway
[12/12/16 14:21:18] …/common/session.c(484): Listen on /home/mike/.ccnet/ccnet.sock for local clients
[12/12/16 14:21:18] …/common/session.c(290): Update pubinfo file
[12/12/16 14:21:19] …/common/session.c(398): Accepted a local client
[12/12/16 14:21:20] …/common/session.c(398): Accepted a local client
[12/12/16 14:21:20] …/common/peer.c(943): Local peer down
[12/12/16 14:21:21] …/common/session.c(398): Accepted a local client
[12/12/16 14:21:52] …/common/peer.c(943): Local peer down
[12/12/16 14:21:58] …/common/peer.c(941): libevent got an error! what=33, errno=104 (Connection reset by peer)
[12/12/16 14:21:58] …/common/peer.c(943): Local peer down
Seafile.log
[12/12/16 14:21:19] seaf-daemon.c(548): starting seafile client 6.0.0
[12/12/16 14:21:19] …/common/mq-mgr.c(60): [mq client] mq cilent is started
[12/12/16 14:21:19] …/common/mq-mgr.c(106): [mq mgr] publish to heartbeat mq: seafile.heartbeat
[12/12/16 14:21:21] sync-mgr.c(660): Repo ‘reservations’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:21] repo-mgr.c(3592): All events are processed for repo 2afff7e4-11f7-4df9-a4c2-499f49ee06ab.
[12/12/16 14:21:21] sync-mgr.c(660): Repo ‘reservations’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:22] sync-mgr.c(660): Repo ‘Personal documents’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:22] repo-mgr.c(3592): All events are processed for repo 021583b6-0041-43b5-88e1-4e6e85fc0d88.
[12/12/16 14:21:22] sync-mgr.c(660): Repo ‘Personal documents’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:23] sync-mgr.c(660): Repo ‘printme’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:23] repo-mgr.c(3592): All events are processed for repo ffb2f7b9-c2b1-4429-b558-4bbe9317e51e.
[12/12/16 14:21:23] sync-mgr.c(660): Repo ‘printme’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:24] sync-mgr.c(660): Repo ‘www’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:24] repo-mgr.c(3592): All events are processed for repo 2d036bcf-e2cd-488e-9854-24039db10c8c.
[12/12/16 14:21:24] sync-mgr.c(660): Repo ‘www’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:25] sync-mgr.c(660): Repo ‘Adventure Inn documents’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:25] repo-mgr.c(3592): All events are processed for repo 3b0edb8f-20ea-41e5-95f5-63280b80b6da.
[12/12/16 14:21:25] sync-mgr.c(660): Repo ‘Adventure Inn documents’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:26] sync-mgr.c(660): Repo ‘mp3s’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:26] repo-mgr.c(3592): All events are processed for repo 1fb5ef9c-b69b-4e98-a879-0c41433e8b21.
[12/12/16 14:21:26] sync-mgr.c(660): Repo ‘mp3s’ sync state transition from ‘committing’ to ‘initializing’.
[12/12/16 14:21:27] sync-mgr.c(660): Repo ‘Photos’ sync state transition from ‘synchronized’ to ‘committing’.
[12/12/16 14:21:27] repo-mgr.c(3592): All events are processed for repo 72c49351-f1c3-49b3-a16b-5cbebdd268b4.
[12/12/16 14:21:27] sync-mgr.c(660): Repo ‘Photos’ sync state transition from ‘committing’ to ‘initializing’.
The libraries are not unsynced. Seaf-daemon process crashed for some reason. Are you able to produce a coredump?
Sorry for taking so long to answer, but I haven’t been at this computer for a while. I have created a core dump, but it’s 50 MB. I also have no idea how to analyze it.
Deleting the ~/Seafile/.seafile-data hidden directory seems to have done the trick. I’m not sure what caused this. I have a backup of this directory, so if anyone is interested in investigating this further, let me know how to remove sensitive items from it and I’ll send it to you.
@Jonathan : I have the same error, same kind of logs, with my new Debian Strectch, unable to use the client (Transport Error).
How can I make a core dump to help solve the problem?
Thanks a lot
The current Seafile client is not compatible with the libssl-1.1 used by Stretch. That’s why the client crashes. We’ll update the code soon to make it compatible with libssl 1.1.
OK, thanks for your answer.
Any idea of the delay?
And also, is it posible to build the client in Stretch? I didn’t manage to do it with the instructions in https://manual.seafile.com/build_seafile/linux.html
Thnak you!
Olivier
Is there stil a problem with libssl-1.1 under Debian Stretch? Just dist-upgraded and have the “unsync” problem.
Seems I forgot to update my seafile repo from jessie
to stretch
. Sorry!
