Greetings,
I actually have the version 5.1.4 of seafile and I wish to upgrade it to 6.0
I’ve downloaded the latest version by running:
wget https://download.seadrive.org/seafile-server_6.3.2_x86-64.tar.gz
And then I ran the upgrade with
root@SEAFILE:/home/Seafile# seafile-server-6.3.2/upgrade/upgrade_5.1_6.0.sh
This script would upgrade your seafile server from 5.1 to 6.0
Press [ENTER] to contiune
[INFO] You are using MySQL
Done
migrating avatars …
Done
updating /home/Seafile/seafile-server-latest symbolic link to /home/Seafile/seafile-server-6.3.2 …
Upgraded your seafile server successfully.
root@SEAFILE:/home/Seafile# ls
ccnet seafile-data seafile-server-latest
conf seafile-server-3.1.7 seahub-data
installed seafile-server-4.3.1 seahub_settings.py
logs seafile-server-5.1.4 seahub_settings.pyc
pids seafile-server-6.3.2 seahub_settings.py.seafile-5.0.0-bak
root@SEAFILE:/home/Seafile# ./seafile-server-latest/seafile.sh start
[08/09/18 10:34:36] …/common/session.c(132): using config file /home/Seafile/conf/ccnet.conf
Starting seafile server, please wait …
Seafile server started
Done.
root@SEAFILE:/home/Seafile# ./seafile-server-latest/seahub.sh start
Error: ‘/home/Seafile/conf/gunicorn.conf’ doesn’t exist
Error:Seahub failed to start.
the problem is that it says that conf/gunicorn.conf is missing
root@SEAFILE:/home/Seafile# ls conf
ccnet.conf seafdav.conf seafile.conf seahub_settings.py seahub_settings.pyc
Any help on that??
Thanks
