Hi @jobenvil
I’m happy other people can use my work, too. Thanks for your kind words.
There’s also a lot of commenting within the bash script, but I will tell you more now and there will also be an README.md later, in case somebody has a question or maybe want to know something to increase the quality of the script
######## variable setup ########
set -o errexit
set -o nounset
grn=$'\e[1;32m'
red=$'\e[1;31m'
end=$'\e[0m'
### the script is written in such a manner that it's important to write a trailing slashs on the variable dir names
https=true #set to true for https usage on your seafile system
“https=true” means that the seafile server is reachable under https.
domain=""
Here you can type in your domain name (IP address should also do it, but it’s not tested)
sea_user=""
User runs the seafile / seahub process
sea_grp=""
Group runs the seafile / seahub process
tmp_dir=""
Temporary directory used for download and unzip the new package of the version
sea_dir=""
Seafile main directory, e.g. /opt/seafile
#log_path="/var/log/"
#log_file="seafile_updater_$(/bin/date -I)"
Logging is not implemented yet. Maybe somebody has an idea. I just put it in there so I won’t forget to implement it in the future.
### get the latest release installed on the server ###
serv_ver=$(/usr/bin/curl -s "${ssl_switch}://${domain}/api2/server-info/" | /usr/bin/awk '/version/{print substr($0, 14, length($0)-46)}')
if [ -z "${serv_ver}" ]; then
echo "${red}error on validate server version!${end}"
exit 1
fi
### get the latest release available on GitHub ###
git_ver=$(/usr/bin/curl -s "https://api.github.com/repos/haiwen/seafile-rpi/releases/latest" | /usr/bin/awk '/tag_name/{print substr($0, 17, length($0)-18)}')
if [ -z "${git_ver}" ]; then
echo "${red}error on validate available git version!${end}"
exit 1
fi
The momentary installed version and the available version from github are pulled by “curl”.
if [ "${serv_ver}" == "${git_ver}" ]; then
echo "${grn}the newest seafile rpi server version is already installed!${end}"
exit 1
The script exits itself and write out this green line if there is no new update available.
else
### do all the parsing of the versions
old_ifs="${IFS}"
IFS='.'
I’m working here with internal field separator for parsing.
init_git_ver=($git_ver)
init_serv_ver=($serv_ver)
git_major=${init_git_ver[0]}
git_minor=${init_git_ver[1]}
git_maint=${init_git_ver[2]}
serv_major=${init_serv_ver[0]}
serv_minor=${init_serv_ver[1]}
serv_maint=${init_serv_ver[2]}
Split the version string with arrays in own characters to discriminate major, minor and maint version numbers.
### set again back to the original internal field separator
IFS="${old_ifs}"
### check if parsing was successfullfy
only_num='^[0-9]$'
for var in $serv_major $serv_minor $serv_maint $git_major $git_minor $git_maint ; do
if ! [[ $var =~ $only_num ]] ; then
echo "${red}variable not a single number - aborted!${end}"
exit 1
fi
done
Here the script checks if parsing was working correctly. @jobenvil: Do you plan to make major, minor and maint versions bigger then one digit, e.g. “6.10.32”?
### if seafile tar-file not already exists
if [ ! -f "${tmp_dir}seafile-server_${git_ver}_stable_pi.tar.gz" ]; then
### get the latest version as tar.gz file from GitHub
/usr/bin/wget "https://github.com/haiwen/seafile-rpi/releases/download/v${git_ver}/seafile-server_${git_ver}_stable_pi.tar.gz" -P "${tmp_dir}" || { /bin/echo "${red}download latest server software package failed${end}"; exit 1; }
Get the latest tar.gz package of the latest version with “wget”.
else
/bin/echo "${red}seafile latest tar.gz already exists in tmp-dir${end}"
exit 1
fi
### if seafile directory not already exists
if [ ! -d "${sea_dir}seafile-server-${git_ver}/" ]; then
### untar the archive
/bin/tar xzf "${tmp_dir}seafile-server_${git_ver}_stable_pi.tar.gz" -C "${tmp_dir}" || { /bin/echo "${red}untar server package failed${end}"; exit 1; }
Using “tar” for unpackaging the tar’ed file.
### move file to seafile working directory
/bin/mv "${tmp_dir}seafile-server-${git_ver}/" "${sea_dir}" || { /bin/echo "${red}move new untar-ed server software package to sea_dir failed${end}"; exit 1; }
Unpacked directory in defined temp directory will be copied to the seafile productive directory.
else
/bin/echo "${red}seafile directory already exists${end}"
exit 1
fi
### setting right folder and file permissions on new folder structure
/bin/chown -R "${sea_user}":"${sea_grp}" "${sea_dir}seafile-server-${git_ver}"/ || { /bin/echo "${red}chown the new server sea_dir failed${end}"; exit 1; }
Set permissions of user and group recursive for new copied seafile directory structure.
### stop all services from seafile before update started
/bin/systemctl stop seafile.service seahub.service || { /bin/echo "${red}stop the seafile and/or seahub service failed${end}"; exit 1; }
Stop the service threw SystemD, like my system is build up. Here i planned one day to implement SysVInit support and other alternative options, too. Maybe somebody can help out there too?
### compare versions if there is a major or minor version upgrade needed
if [ "${git_major}" -gt "${serv_major}" ] || [ "${git_minor}" -gt "${serv_minor}" ] ; then
### execute all needed incremental update scripts
for path in $(/bin/ls "${sea_dir}seafile-server-${git_ver}"/upgrade/upgrade_*.sh); do
script=$(basename "$path")
old_ifs="${IFS}"
IFS='._'
init_script=($script)
script_major=${init_script[1]}
script_minor=${init_script[2]}
IFS="${old_ifs}"
### search for necessary update scripts
Here the routine search for all necessary upgrade scripts needed to be installed. I hope I designed it so that major, minor and maint version upgrades will work independed with the version you start with.
if [ "${script_major}" -gt "${serv_major}" ] || [ "${script_major}" -eq "${serv_major}" ] && [ "${script_minor}" -ge "${serv_minor}" ]; then
/bin/su - "${sea_user}" -s /bin/bash -c "cd ${sea_dir}seafile-server-${git_ver}/ && upgrade/${script}" || { /bin/echo "${red}update script failed!${end}"; exit 1; }
Install the necessary scripts for major and minor upgrades one by one if needed.
fi
done
### compare versions if there is a maint version upgrade needed
elif [ "${git_maint}" -gt "${serv_maint}" ] ; then
### exexute the upgrade script itself
/bin/su - "${sea_user}" -s /bin/bash -c "cd ${sea_dir}seafile-server-${git_ver} && upgrade/minor-upgrade.sh" || { /bin/echo "${red}update script failed!${end}"; exit 1; }
Execute minor-upgrade script only if last number of version (maint) is higher.
fi
### seafile services start again
/bin/systemctl start seafile.service seahub.service || { /bin/echo "${red}start the seafile and/or seahub service failed${end}"; exit 1; }
Start seafile and seahub service again over SystemD
### verfiy if correct version of seafile server software is installed
try=0
until [ $try -ge 5 ]; do
verify_ver=$(/usr/bin/curl -s --connect-timeout 30 "${ssl_switch}://${domain}/api2/server-info/" | /usr/bin/awk '/version/{print substr($0, 14, length($0)-46)}')
[ -n "${verify_ver}" ] && break
try=$((try+1))
sleep 10
done
ver_num='^[0-9].[0-9].[0-9]$'
if ! [[ $verify_ver =~ $ver_num ]] ; then
exit 1
fi
if [ "${git_ver}" == "${verify_ver}" ]; then
Test if the API call with “curl” for the version was correct and compare so that the new installed version is fine.
### move old seafile version to installed dir as an archive for a possible rollback scenario
/bin/mv "${sea_dir}seafile-server-${serv_ver}" "${sea_dir}installed/" || { /bin/echo "${red}move to archive dir failed${end}"; exit 1; }
### delete old temporary files and archives
/bin/rm -rf "${tmp_dir}"* || { /bin/echo "${red}remove temporary files and directories failed${end}"; exit 1; }
Do some cleanup jobs. (Move old seafile directory to /installed and remove temporary files)
else
echo "${red}a bigger problem is occured, no new version was installed!${end}"
If there’s an error with the validation of server version over the API call this error will occur.
fi
fi
