Hi! I’m trying to get my old trusty server decoupled from its nginx service, as I have a bunch of other subdomains being served, and the future plan is to keep in separated containers. I have a new nginx LXC container, and I installed nginx onto it. I copied the Seafile nginx config and SSL certs onto it, changing the proxy_pass addresses (where before it was http://127.0.0.1:8000 now it’s http://192.168.0.15:8000, and so on) and the /media path accordingly, but I’m getting 502 errors when I try to go through the new nginx container.
This is the new configuration:
# Required for OnlyOffice DocumentServer
"" $scheme;
"" $host;
default upgrade;
"" close;
listen 80;
server_name myserver.com;
server_tokens off;
listen 443;
ssl on;
# Let's Encrypt cert
ssl_certificate /etc/letsencrypt/live/myserver.com/fullchain.pem; # managed by Certbot
# path to your cacert.pem
ssl_certificate_key /etc/letsencrypt/live/myserver.com/privkey.pem; # managed by Certbot
server_tokens off;
#let's encrypt
location ^~ /.well-known/acme-challenge {
default_type "text/plain";
root /etc/letsencrypt/live/myserver.com;
#TLS 1.3
ssl_protocols TLSv1.2 TLSv1.3;
proxy_pass http://192.168.0.15:8000;
proxy_set_header Host $host;
proxy_read_timeout 1200s;
proxy_pass http://192.168.0.15:8092;
proxy_connect_timeout 36000s;
proxy_read_timeout 36000s;
proxy_send_timeout 36000s;
proxy_request_buffering on; #doesn't work until nginx v1.7.11 currently v1.4
root /media/Seafile/seafile-server-latest/seahub;
location /onlyofficeds/ {
proxy_pass http://192.168.0.15:88/;
proxy_http_version 1.1;
proxy_read_timeout 3600s;
proxy_connect_timeout 3600s;
However, as mentioned, this doesn’t bring joy. It gets me a 502 Bad Gateway. The only difference between this file and the original from the Seafile server residing on the 192.168.0.15 is the change from 127.0.0.1 to the Seafile IP. Oh, and the /media relative path, of course. But as you can see, this is not a /media issue, as I don’t even get there…I get a 502 before I get a chance.
