Seafile Pro 6.3.6
CentOS 7
After a yum update the seahub process doesn’t start anymore.
the seahub log says:
2021-10-26 13:32:33,110 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:33:10,380 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:33:10,434 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:33:47,439 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:33:47,482 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:34:23,406 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:34:23,446 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:34:59,377 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:34:59,419 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:35:35,678 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:35:35,770 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:36:11,680 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:36:11,725 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:36:47,644 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:36:47,687 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:36:52,180 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:36:52,227 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:37:28,195 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:37:28,240 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:38:04,507 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:38:04,557 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:38:40,686 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:38:40,730 [INFO] seafevents:109 is_audit_enabled audit is enabled
2021-10-26 13:39:16,707 [INFO] seafevents.db:74 create_engine_from_conf [seafevents] database: mysql, name: SF_seahub
2021-10-26 13:39:16,899 [INFO] seafevents:109 is_audit_enabled audit is enabled
ccnet.log
[10/26/21 15:42:31] ../common/session.c(409): Accepted a local client
[10/26/21 15:42:31] ../common/peer.c(950): Local peer down
[10/26/21 15:43:07] ../common/session.c(409): Accepted a local client
[10/26/21 15:43:07] ../common/peer.c(950): Local peer down
[10/26/21 15:43:44] ../common/session.c(409): Accepted a local client
[10/26/21 15:43:44] ../common/peer.c(950): Local peer down
gunicorn_error.log
[2021-10-26 13:45:34 +0000] [18797] [ERROR] Connection in use: ('0.0.0.0', 8000)
[2021-10-26 13:45:34 +0000] [18797] [ERROR] Retrying in 1 second.
[2021-10-26 13:45:35 +0000] [18797] [ERROR] Connection in use: ('0.0.0.0', 8000)
[2021-10-26 13:45:35 +0000] [18797] [ERROR] Retrying in 1 second.
[2021-10-26 13:45:36 +0000] [18797] [ERROR] Connection in use: ('0.0.0.0', 8000)
[2021-10-26 13:45:36 +0000] [18797] [ERROR] Retrying in 1 second.
[2021-10-26 13:45:37 +0000] [18797] [ERROR] Connection in use: ('0.0.0.0', 8000)
[2021-10-26 13:45:37 +0000] [18797] [ERROR] Retrying in 1 second.
[2021-10-26 13:45:38 +0000] [18797] [ERROR] Can't connect to ('0.0.0.0', 8000)
not very useful.
Seafile process does run. Any help is highly appreciated.
