Hi, im runnning Seafile 6.0.7 on Windows Server 2016 Standard. I have a couple of them working, so please dont comment with suggestions to go to linux because it is possible.
What I deployed so far:
- Installed Python 2.7 and added its installation path to the system environment
- Initialised seafile server
- Created 3 database as shown in the seafile manual
- Installed Pyhton MySQL Tools
- Executed mysql.sql script successfully on seahub-db
- Added them to the configs
NOTE: At this point seafile was working well.
- Installed IIS and added a Seafile Website with HTTPS on Port 443
- Installed Application Request Rounting Proxy Server Pass Through for URL Rewrite
- Added 2 Rules for rewriting Request to the seafhttp or the webinterface Port 8000 and 8082
- Added a Zone in DNS for my URL which is resolving the IP of my server
- Changed SERVICE_URL to my URL and added FILE_SERVER_ROOT
NOTE: Now when Im trying to reach my site via the URL it says BAD GATEWAY. But I noticed that my pyhton background process is not started. So it is clear that i cant reach seahub webinterface.
What I did troubleshoot so far:
- Checking Rewrite Rules
- Checking all Configs
- Checking if there are already hidden python background processes
- Try to run manage.py from Commandline and Python Commandline
- Checking User Permission
- Reroll the configs to before installing IIS (didn’t work)
- Checking Firewall
I had to delete the whole seafile database. The manage.py background process did start again.
The Error Messages:
Starting manage.py from IDLE with “runserver localhost:8000”
Fun Fact this error shows up on my other seafile server too but they are working…
===== RESTART: C:\Seafile Program\seafile-server-6.0.7\seahub\manage.py =====
File "C:\Seafile Program\seafile-server-6.0.7\seahub\manage.py", line 8, in <module>
from django.core.management import execute_from_command_line
ImportError: No module named django.core.management
From Seafserv.log
created "python.exe -V", pid 5976
[12/19/17 10:57:35] seafserv/seafserv.c(63): starting ccnet-server ...
[12/19/17 10:57:35] created "ccnet-server.exe -c "D:/seafile-server\ccnet" -f "D:/seafile-server\logs\ccnet.log" -F "D:/seafile-server\conf"", pid 3912
[12/19/17 10:57:35] seafserv/seafserv.c(466): ccnet server started
[12/19/17 10:57:36] seafserv/seafserv.c(334): trying to connect to ccnet-sever...
[12/19/17 10:57:36] seafserv/seafserv.c(360): connected to ccnet server
[12/19/17 10:57:36] seafserv/seafserv.c(90): starting seaf-server ...
[12/19/17 10:57:36] created "seaf-server.exe -c "D:/seafile-server\ccnet" -d "D:/seafile-server\seafile-data" -l "D:/seafile-server\logs\seafile.log" -F "D:/seafile-server\conf"", pid 4828
[12/19/17 10:57:36] seafserv/seafserv.c(161): starting seahub ...
[12/19/17 10:57:36] created "python.exe "C:\Seafile Program\seafile-server-6.0.7\seafile\bin\..\..\seahub\manage.py" runwsgiserver host=0.0.0.0 port=8080 autoreload=False staticserve=False", pid 3964
[12/19/17 10:57:36] seafserv/seafserv.c(560): [process monitor] started.
[12/19/17 10:58:26] seafserv/seafserv.c(516): seahub has exited with code 1
[12/19/17 10:58:26] seafserv/seafserv.c(161): starting seahub ...
[12/19/17 10:58:26] created "python.exe "C:\Seafile Program\seafile-server-6.0.7\seafile\bin\..\..\seahub\manage.py" runwsgiserver host=0.0.0.0 port=8080 autoreload=False staticserve=False", pid 4296
[12/19/17 10:59:16] seafserv/seafserv.c(516): seahub has exited with code 1
Its looping over and over again that it creates the pyhton background process and the it immediatly gets shut down.
My Configs:
ccnet.conf
[General]
USER_NAME = my-seafile
ID = editedbecausesecret
NAME = my-seafile
SERVICE_URL = https://url.mydomain.de:8080
[Network]
PORT = 10001
[Client]
PORT = 13418
#MySQL Connection (Seafiledb: ccnet-db)
[Database]
ENGINE=mysql
HOST=localhost
USER=seafile
PASSWD=********
DB=ccnet-db
seafile.conf
#MySQL Connection (SeafileDb: seafile-db)
[database]
type=mysql
host=localhost
user=seafile
password=********
db_name=seafile-db
[network]
port = 12001
[fileserver]
port = 8082
[seahub]
port = 8080
fastcgi = false
seahub_settings.py
SECRET_KEY = edited because secret
#Seafile File-Server Root fĂĽr Upload/Download von Daten
FILE_SERVER_ROOT = 'https://url.mydomain.de/seafhttp'
#MySQL Connection (SeafileDb: seahub-db)
DATABASES = {
'default': {
'NAME' : 'seahub-db',
'USER' : 'seafile',
'PASSWORD' : '**********',
'HOST' : 'localhost',
'PORT' : '3306',
