So I have just installed Seafile server, started both seafile and seahub and tried opening the hub on port 8000. It doesn’t work. Times out when I cURL using the external and the local IP. I have also tried configuring it with an nginx proxy and still doesn’t work.
I have also tried starting the hub in port 8080/8081 (also changing ccnet.conf).
Shouldn’t it work out of the box when you run the setup? I’m a little confused.
