I think I found a little UI bug in seafile 12.0.7. I didn’t deploy the seadoc stuff, and in my .env file I have ENABLE_SEADOC=false and I commented out the SEADOC_SERVER_URL= and other SEADOC* options. In the web interface, there is still the “Wikis” section on the left panel, with the little arrow to let me make a new wiki.
It will create the library and the first page, but then gives an error, that just says “Error”.
That error seems to be because of a 404 error loading https://my.seafile.domain/sdoc-server/api/v1/docs/9...4/ which isn’t surprising since I don’t have seadoc, so I don’t have anything at /sdoc-server
The documentation at seahub_settings.py - Seafile Admin Manual says:
# Whether enable the feature "published library". Default is `False`
# Since 6.1.0 CE
ENABLE_WIKI = True
But that comment seems to be wrong, it seems to default to true. I had to add that config option and set it to False turn off the wiki to prevent users from trying to use the broken wiki stuff.
