Hey guys!
Today I updated Seafile from 9 to 10 and 10 to 11 and now Sehub wont start anymore.
The only “error message” I get ist this:
Error:Seahub failed to start.
I also updatet my Debian 11.11 to 12.8 today and set the Python3 version to 3.11.2 for the seafile user (former 3.6). I also set an virtual envoronment. I tried to install all new necessary libs in both environments but always fail.
Buuut, when I try to install python_ldap I get this error:
Building wheels for collected packages: python-ldap
Building wheel for python-ldap (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for python-ldap (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [82 lines of output]
/tmp/pip-build-env-xnlxhyk5/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py:261: UserWarning: Unknown distribution option: 'test_suite'
warnings.warn(msg)
running bdist_wheel
running build
running build_py
creating build/lib.linux-x86_64-cpython-311
copying Lib/ldapurl.py -> build/lib.linux-x86_64-cpython-311
copying Lib/ldif.py -> build/lib.linux-x86_64-cpython-311
creating build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/cidict.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/resiter.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/filter.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/sasl.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/compat.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/logger.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/pkginfo.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/syncrepl.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/dn.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/ldapobject.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/constants.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/async.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/functions.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/asyncsearch.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/modlist.py -> build/lib.linux-x86_64-cpython-311/ldap
copying Lib/ldap/__init__.py -> build/lib.linux-x86_64-cpython-311/ldap
creating build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/psearch.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/sessiontrack.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/pwdpolicy.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/simple.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/vlv.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/pagedresults.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/ppolicy.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/deref.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/libldap.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/openldap.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/sss.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/__init__.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
copying Lib/ldap/controls/readentry.py -> build/lib.linux-x86_64-cpython-311/ldap/controls
creating build/lib.linux-x86_64-cpython-311/ldap/extop
copying Lib/ldap/extop/passwd.py -> build/lib.linux-x86_64-cpython-311/ldap/extop
copying Lib/ldap/extop/dds.py -> build/lib.linux-x86_64-cpython-311/ldap/extop
copying Lib/ldap/extop/__init__.py -> build/lib.linux-x86_64-cpython-311/ldap/extop
creating build/lib.linux-x86_64-cpython-311/ldap/schema
copying Lib/ldap/schema/tokenizer.py -> build/lib.linux-x86_64-cpython-311/ldap/schema
copying Lib/ldap/schema/models.py -> build/lib.linux-x86_64-cpython-311/ldap/schema
copying Lib/ldap/schema/subentry.py -> build/lib.linux-x86_64-cpython-311/ldap/schema
copying Lib/ldap/schema/__init__.py -> build/lib.linux-x86_64-cpython-311/ldap/schema
creating build/lib.linux-x86_64-cpython-311/slapdtest
copying Lib/slapdtest/_slapdtest.py -> build/lib.linux-x86_64-cpython-311/slapdtest
copying Lib/slapdtest/__init__.py -> build/lib.linux-x86_64-cpython-311/slapdtest
running egg_info
writing Lib/python_ldap.egg-info/PKG-INFO
writing dependency_links to Lib/python_ldap.egg-info/dependency_links.txt
writing requirements to Lib/python_ldap.egg-info/requires.txt
writing top-level names to Lib/python_ldap.egg-info/top_level.txt
reading manifest file 'Lib/python_ldap.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'Doc/.build'
adding license file 'LICENCE'
writing manifest file 'Lib/python_ldap.egg-info/SOURCES.txt'
creating build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/README -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/ca.conf -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/ca.pem -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/client.conf -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/client.key -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/client.pem -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/gencerts.sh -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/gennssdb.sh -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/server.conf -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/server.key -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
copying Lib/slapdtest/certs/server.pem -> build/lib.linux-x86_64-cpython-311/slapdtest/certs
running build_ext
building '_ldap' extension
creating build/temp.linux-x86_64-cpython-311/Modules
x86_64-linux-gnu-gcc -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DHAVE_SASL -DHAVE_TLS -DLDAPMODULE_VERSION=3.4.3 "-DLDAPMODULE_AUTHOR=python-ldap project" "-DLDAPMODULE_LICENSE=Python style" -IModules -I/home/seafile/include -I/usr/include/python3.11 -c Modules/LDAPObject.c -o build/temp.linux-x86_64-cpython-311/Modules/LDAPObject.o
Modules/LDAPObject.c:16:10: fatal error: sasl/sasl.h: No such file or directory
16 | #include <sasl/sasl.h>
compilation terminated.
error: command '/usr/bin/x86_64-linux-gnu-gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for python-ldap
Failed to build python-ldap
ERROR: Could not build wheels for python-ldap, which is required to install pyproject.toml-based projects
I don’t use LDAP so I don’t know if this lib is important to run seahub 11?
python3-dev ldap-utils libldap2-dev is installed. Seafile runs without any errors. MySQL migration wasn’t necessary because I used it from first installation.
If you need some additional information please tell me.
