Seahub won't start after upgrade to 12
Today I’ve upgraded Seafile from 11 to 12. I’ve done all the required steps on the upgrade notes but seahub won’t start now.
Steps that I’ve done:
  1. Upgraded python libraries
  2. Created the .env file and adjust settings
  3. run the upgrade script
When i started seafile it is starting without error. But seahub gives error below:
./seahub.sh start
Cannot find JWT_PRIVATE_KEY value from environment, try to read .env file.
Error:Seahub failed to start.
Any idea?
Where can i look to identify the problem.
Edit: Seafile Pro Edition
I find the error caused the issue. When i look at the seafile-monitor.log there is a line that says “ModuleNotFoundError: No module named ‘pylibmc’”. When i install pylibmc with pip install pylibmc, seahub successfully started.
