I have a mostly working Seafile setup on an Ubuntu 20.04. I could reproduce the following with the releases 8.0.3 and 8.0.5.
As suggested in the manual, I have to remove the files …/seafile-server-latest/seafile/libs/{liblber-2.4.so.2,libldap-2.4.so.2,libsasl2.so.3} to get connections to the LDAP server working.
However, with these files removed Seahub stops working and guessing from the following stack trace, it seems that the database connection doesn’t work anymore:
seahub.log
2021-05-20 17:54:58,355 [ERROR] django.request:222 log_response Internal Server Error: /
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/named_pipe.py", line 88, in _get_transport
transport = self._pool.get(False)
File "/usr/lib/python3.8/queue.py", line 167, in get
raise Empty
_queue.Empty
File "/opt/seafile/seafile-server-8.0.5/seahub/thirdpart/django/core/handlers/exception.py", line 34, in inner
File "/opt/seafile/seafile-server-8.0.5/seahub/thirdpart/django/utils/deprecation.py", line 93, in __call__
response = self.process_request(request)
File "/opt/seafile/seafile-server-8.0.5/seahub/seahub/auth/middleware.py", line 33, in process_request
if request.user.is_authenticated and not request.user.is_active:
File "/opt/seafile/seafile-server-8.0.5/seahub/seahub/auth/middleware.py", line 23, in __get__
request._cached_user = get_user(request)
File "/opt/seafile/seafile-server-8.0.5/seahub/seahub/auth/__init__.py", line 120, in get_user
user = backend.get_user(username) or AnonymousUser()
File "/opt/seafile/seafile-server-8.0.5/seahub/seahub/base/accounts.py", line 573, in get_user
user = self.get_user_with_import(username)
File "/opt/seafile/seafile-server-8.0.5/seahub/seahub/base/accounts.py", line 544, in get_user_with_import
emailuser = ccnet_api.get_emailuser_with_import(username)
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/seaserv/api.py", line 896, in get_emailuser_with_import
return ccnet_threaded_rpc.get_emailuser_with_import(email)
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/client.py", line 126, in newfunc
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/named_pipe.py", line 100, in call_remote_func_sync
transport = self._get_transport()
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/named_pipe.py", line 90, in _get_transport
transport = self._create_transport()
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/named_pipe.py", line 83, in _create_transport
transport.connect()
File "/opt/seafile/seafile-server-8.0.5/seafile/lib64/python3.6/site-packages/pysearpc/named_pipe.py", line 47, in connect
self.pipe.connect(self.socket_path)
ConnectionRefusedError: [Errno 111] Connection refused
I could verify that the LDAP connection is working as I could see an imported LDAP user in the web interface after undoing the file deletion and logging in with an admin user that is stored in the database.
I have checked the permissions of seafile-server-8.0.x/runtime/seafile.sock, they’re assigned to the user that runs the processes.
What’s irritating as well is that with the library files in place Seafile logs on startup in seafile.log:
0021-05-20 18:01:58 socket file exists, delete it anyway
2021-05-20 18:01:58 ../common/seaf-utils.c(333): Use database Mysql
2021-05-20 18:01:58 http-server.c(192): fileserver: worker_threads = 20
2021-05-20 18:01:58 http-server.c(207): fileserver: fixed_block_size = 8388608
2021-05-20 18:01:58 http-server.c(222): fileserver: web_token_expire_time = 3600
2021-05-20 18:01:58 http-server.c(237): fileserver: max_indexing_threads = 1
2021-05-20 18:01:58 http-server.c(252): fileserver: max_index_processing_threads= 3
2021-05-20 18:01:58 http-server.c(274): fileserver: cluster_shared_temp_file_mode = 600
2021-05-20 18:01:58 ../common/seaf-db.c(729): Failed to connect to MySQL: Lost connection to MySQL server at 'handshake: reading inital communication packet', system error: 11
2021-05-20 18:01:58 repo-mgr.c(3661): Failed to add branch.
2021-05-20 18:01:58 seafile-session.c(406): Failed to create system default repo.
2021-05-20 18:02:02 start to serve on pipe client
in contrast to the state where the files are removed, nothing is logged at all. except for the output of seafile.sh to stdout that is captured by journald.
i’d appreciate any suggestion for further troubleshooting and a solution to overcome this situation.
