The update from CE12 to 13 running under docker went smoothly. Thank you for the good work!
Simple questions after the update:
- the entry SEAFILE_MEMCACHED_IMAGE=memcached:1.6.29 can be removed from .env after the switch to redis, right?
- my ./seafile-data/seafile/conf/seafile.conf still contains a section “[notification]” as it wasn’t mentioned in the update doc. Should I keep or remove it.
Thanks again!
Martin
