[SOLVED] 7.0.5 CE to 7.1.2 CE Upgrade Gives WebDAV 502 Error
I just upgraded a working 7.0.5 CE Ubuntu 18/Nginx server to 7.1.2 CE. Everything works except WebDAV which gives a 502 - Bad Gateway - in a browser and “Could not connect to server” by a previously working WebDAV client.
In the process of the upgrade I removed the WebDAV fastcgi location in Nginx (“After Seafile 7.1.x, Seafdav does not support Fastcgi, only Wsgi.”) and replaced it with the sample code found in the upgrade notes.
location /seafdav {
    proxy_pass         http://127.0.0.1:8080/seafdav;
    proxy_read_timeout  1200s;
    access_log      /var/log/nginx/seafdav.access.log seafileformat;
This obviously did not work. Comparing and substituting the similar seafdav block found in the CE Manual also did not work.
Seafile’s configuration file seafdav.conf reads (toggled fastcgi false):
[WEBDAV]
enabled = true
port = 8080
host = 127.0.0.1
fastcgi = false
share_name = /seafdav
I was using port 8080 previously so no changes in ports have taken place or were required.
Presently I am not seeing anything using port 8080 (netstat -tulpen) when I start the server.
As an example, when I try to access the WebDAV server using a browser the error log shows:
2020/03/22 18:47:13 [error] 1269#1269: *159 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.2.1, server: host.ddns.net, request: “GET /seafdav HTTP/2.0”, upstream: “http://127.0.0.1:8080/seafdav”, host: “host.ddns.net”
Similarly, the access log shows for the same event:
192.168.2.1 - - [22/Mar/2020:18:47:13 -0600] “GET /seafdav HTTP/2.0” 502 166 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:74.0) Gecko/20100101 Firefox/74.0”
I’m at a loss to explain this failure despite going through all the posts on WebDAV, 7.1 upgrades and 502 errors.
Does anyone have a suggestion on where to look next?
Is it possible the WSGI itself is somehow the issue? If so, how do I check that?
PS.
The Seafile Controller log has this recurring entry regarding the seafdav process and pid. It appears that seafdav never launches. No seafdav.pid file appears in the pids folder.
[03/22/20 22:33:05] seafile-controller.c(414): pid file /home/seafile/seafile-server/pids/seafdav.pid does not exist
[03/22/20 22:33:05] seafile-controller.c(446): seafdav need restart…
[03/22/20 22:33:05] seafile-controller.c(79): spawn_process: /usr/bin/python3 -m wsgidav.server.server_cli --server gunicorn --root / --log-file /home/seafile/seafile-server/logs/seafdav.log --pid /home/seafile/seafile-server/pids/seafdav.pid --port 8080 --host 127.0.0.1
[03/22/20 22:33:05] seafile-controller.c(94): spawned /usr/bin/python3, pid 8840
PPS.
WsgiDAV (3.0.2)
-Thank you
Looking back over all the posts on WebDAV 502 errors I decided to check that all the software dependencies were met for the upgrade to 7.1.2.
The Manual specifically calls out
pip3 install --timeout=3600 Pillow pylibmc captcha jinja2 sqlalchemy psd-tools django-pylibmc django-simple-captcha python3-ldap
For those who come after it might be worth mentioning that pip3 might need to be installed in your system too.
sudo apt install python3-pip
You can check if it’s installed and its version using:
pip3 -V
@Jonathan warns against installing WSGI manually (‘pip3 install wsgidav’) but you can check for it using
pip3 list
I made the mistake of installing wsgidav from the command line, however. Once I ran
a second time, as suggested in the Manual, the problem corrected and I finally got WebDAV to run. It seems to be working again.
As a side note, I received no errors or warnings about software dependencies from the upgrade script when updating to 7.1.2.
