Hello !
This new thread follows the previous conversation I had with @wthess on the Tutorial for using free SSL/TLS certificates provided by “letsencrypt”.
The main issue was that i continuously got the following error while trying to use certbot-auto:
[quote]Failed authorization procedure. mydomain.fr (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://mydomain.fr/.well-known/acme-challenge/xW5e-ssGxezDEPUIE2UJZRoLU08n_1sOzad6jTLc4N0 [2001:1600:4:1::b]: 404
IMPORTANT NOTES:
The following errors were reported by the server:
Domain: mydomain.fr
Type: unauthorized
Detail: Invalid response from
[2001:1600:4:1::b]: 404To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.[/quote]
Here was my seafile.conf on nginx:
[quote]server {
listen 80;
listen [::]:80;
server_name mydomain.fr;
rewrite ^ https://$http_host$request_uri? permanent; # force redirect ht$
# Enables or disables emitting nginx version on error pages and in the "Ser$
server_tokens off;
location /.well-known/acme-challenge {
default_type “text/plain”;
allow all;
root /home/pi/certbot-webroot;
listen 443;
listen [::]:443;
ssl on;
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
error_page 497 https://$host:$server_port$request_uri;
fastcgi_pass 127.0.0.1:8000 ;
fastcgi_param HTTPS on;
root /home/pi/seafile/seafile-server-latest/seahub;
allow all;
}[/quote]
After a lot of investigation, with the help of @wthess, it belongs that the error was “only” due to IPv6. It appears that, if Certbot-auto “detects” the IPv6 activated on your domain, it will favor this way of working. So if it gets back an error on IPv6, it will not try on IPv4 and will return you the 404 error.
So the solution was to delete the DNS AAAA redirection in my domain gestion interface. After this was done, certbot-auto doesn’t “detect” IPv6 on my domain and work so with IPv4.
I thanks a lot @wthess for his help, and let him brings some precision on this issue.
Hope this thread can help.
PS: Sorry for my poor english… i’m from France
