Hi
This is a fresh Seafile install on a fresh install Ubuntu 16.04 Hetzner Server.
Seafile server 6.2.5
Something went wrong with my memcached, which I can see in the sehub.log (see below in this post).
I am not sure about memcached and how to fix it.
So I am posting this, hoping that someone might be able to give me a quick solution, although I probably should do a memcached research…
The problem I have is that seahub.log is full of errors as pasted below and the issue I have is this:
When a user clicks on “sign up” on the Seafile start page, then no Email gets sent and the next webpage page gives and error:
Page unavailable
This is the seahub_setting.py:
SECRET_KEY = “xxx”
FILE_SERVER_ROOT = ‘https://cloud2.example.com/seafhttp’
CLOUD_MODE = True
ENABLE_GLOBAL_ADDRESSBOOK = False
TIME_ZONE = ‘Europe/Berlin’
SITE_NAME = ‘cloud2.example.com’
SITE_TITLE = ‘YNA CLoud’
SEND_EMAIL_ON_ADDING_SYSTEM_MEMBER = False
EMAIL_USE_TLS = True
EMAIL_HOST = ‘mail.example.com’ # smtp server
EMAIL_HOST_USER = ‘admin@example.com’ # username and domain
EMAIL_HOST_PASSWORD = ‘xxx’ # password
EMAIL_PORT = ‘587’
DATABASES = {
‘default’: {
‘NAME’: ‘seahub-db’,
‘USER’: ‘seafile’,
‘PASSWORD’: ‘xxx’,
‘HOST’: ‘127.0.0.1’,
‘PORT’: ‘3306’
CACHES = {
‘default’: {
‘BACKEND’: ‘django_pylibmc.memcached.PyLibMCCache’,
‘LOCATION’: ‘127.0.0.1:11211’,
This is ccnet.conf:
And this is the seahub_django_request.log
2018-03-26 09:47:15,021 [ERROR] django.request:256 handle_uncaught_exception Internal Server Error: /accounts/register/
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/handlers/base.py”, line 132, in get_response
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/registration/views.py”, line 197, in register
new_user = backend.register(request, **form.cleaned_data)
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/seahub/base/accounts.py”, line 583, in register
send_email=config.REGISTRATION_SEND_MAIL)
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/registration/models.py”, line 93, in create_inactive_user
send_email, is_active=False)
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/registration/models.py”, line 85, in create_email_user
registration_profile.send_activation_email(site)
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/registration/models.py”, line 285, in send_activation_email
ctx_dict, None, [user.username])
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/seahub/utils/init.py”, line 827, in send_html_email
msg.send()
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/mail/message.py”, line 303, in send
return self.get_connection(fail_silently).send_messages([self])
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/mail/backends/smtp.py”, line 100, in send_messages
new_conn_created = self.open()
File “/home/ck/seafile.cloud/seafile-server-6.2.5/seahub/thirdpart/Django-1.8.18-py2.7.egg/django/core/mail/backends/smtp.py”, line 58, in open
self.connection = connection_class(self.host, self.port, **connection_params)
File “/usr/lib/python2.7/smtplib.py”, line 256, in init
(code, msg) = self.connect(host, port)
File “/usr/lib/python2.7/smtplib.py”, line 316, in connect
self.sock = self._get_socket(host, port, self.timeout)
File “/usr/lib/python2.7/smtplib.py”, line 291, in _get_socket
return socket.create_connection((host, port), timeout)
File “/usr/lib/python2.7/socket.py”, line 575, in create_connection
raise err
error: [Errno 111] Connection refused
2018-03-26 09:47:15,255 [WARNING] django.request:170 get_response Not Found: /favicon.ico
And this is Seahub.log:
2018-03-26 09:47:15,271 [ERROR] django.pylibmc:146 set MemcachedError: error 47 from memcached_set: (0x23ae5e0) SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY, host: 127.0.0.1:11211 → libmemcached/connect.cc:720
File “/usr/local/lib/python2.7/dist-packages/django_pylibmc/memcached.py”, line 140, in set
**COMPRESS_KWARGS)
ServerDown: error 47 from memcached_set: (0x23ae5e0) SERVER HAS FAILED AND IS DISABLED UNTIL TIMED RETRY, host: 127.0.0.1:11211 → libmemcached/connect.cc:720
