I want Seahub to show up under this domain: https://seafile.timohausmann.de/
As you can see, the SSL Cert is valid, but Seahub gives me a “Bad Request (400)”.
Hm, which logs did you think of? Nothing gets written to Seafile logs upon the Bad Request (400). Only in seahub_django_request.log I find these errors, but I think they are unrelated:
2018-09-13 00:35:25,262 [WARNING] django.request:170 get_response Not Found: /manager/html
2018-09-13 09:44:28,100 [WARNING] django.request:170 get_response Not Found: /seafhttp/protocol-version
In the apache2 logs I only see the GET request inside access.log, nothing else.
Also, it makes zero sense to me that Seahub is still reachable under http and Port 8000.
Unless you forbid it using a firewall it will be reachable.
Looking at the log there seem to be multiple issues. 1. Your webserver redirects Seafile server requests to seahub and 2. It redirects requests from another application to seahub
If you want to only process request on port 8000 sent by the local machine (the apache proxy), on conf/gunicorn.conf edit the line that starts with bind = to:
import os
daemon = True
workers = 5
# default localhost:8000
bind = "0.0.0.0:8000" # !Edit this to "localhost:8000"!
# Pid
pids_dir = '/home/fakui/seafile-server-tests/pids'
# Logging
logs_dir = '/home/fakui/seafile-server-tests/logs'
errorlog = os.path.join(logs_dir, 'gunicorn_error.log')
accesslog = os.path.join(logs_dir, 'gunicorn_access.log')
timeout = 1200
limit_request_line = 8190
I didn’t even had a gunicorn.conf so first I upgraded from 6.1.1 to current release. Then django said:
[ERROR] django.security.DisallowedHost:80 response_for_exception Invalid HTTP_HOST header: '127.0.0.1:8000'. You may need to add u'127.0.0.1' to ALLOWED_HOSTS.
I did that in seahub_settings.py and now it works! Also closed public port 8000.
I tried both bind = “0.0.0.0:8000” and “localhost:8000”, both seem to work
